Front Bumper/Winch Plate Build! (pic heavy) - Page 6 - JeepForum.com
post #76 of 111 Old 03-07-2010, 05:46 PM Thread Starter
MO2500
Originally Posted by Djay101 View Post
that helps a bit, thanks!!
Not a problem. Let me know if you have anymore questions and i'll be happy to try and answer them. Thats what this forums all about
Originally Posted by 2doorxj View Post
wow that looks awesome, nice fab skillz
Thanks man! stay tuned for a rear bumper and tire carrier build. I'm researching now for what i'm gonna need to start that in not to long.
Instagram: @omsmike
MO2500 is offline
post #77 of 111 Old 03-07-2010, 09:02 PM
Djay101
right now ive got the original bumper on the jeep... im getting the metal this summer to build a bumper possibially, ive got round tube for the nerf bars and going to try and find a tube bender... i might just have the tube bars come out had have them angled in towards the jeep on the ends and square tubing going back in onto the frame. and a plate for the winch/ball is in the works right now... the ball right now when im winching pulls upwards when under tow... its just temporary right now... im looking at putting on a square tube on the bumper so i could put a receiver hitch on... planning right now how i want the bumper to look...
Djay101 is offline
post #78 of 111 Old 03-07-2010, 09:06 PM
rybicki
awesome thanks mo! I'm actually just running flux right now but I'll definatly look into the c25 I just didnt have the money at the time that I bought the welder but now I'm starting to get more tools in my garage so I can start my build. Get my 30gal air compressor tomorrow cant wait! but definatly need to find a place where I can pick up metal from so I can practice and have a go to place once I start my fab work.
oh almost forgot to ask... what was the reasoning for offsetting the welds in front and in back?
Ribeye
rybicki is offline
post #79 of 111 Old 07-05-2010, 10:26 AM
ALRubicon
Wow! Your bumper looks great. I bought the materials a few months ago for bumpers and this is exactly what I want to do.
Was there no room to move the winch back a little so that you would have more clearance around the bolts?
ALRubicon is offline
post #80 of 111 Old 07-05-2010, 09:43 PM Thread Starter
MO2500
Thanks
With the stock anti-sway bar there was just now way to move the winch back any and still keep the bumper tight against the frame. With something like the Currie Antirock (ordered one today actually ) that goes through the front crossmember there would be plenty of room. I didn't have to remove too much material from the bumper to turn the head on the bolt though. Just a slight shaving with the grinder, didn't even cut all the way through into the tube.
Instagram: @omsmike
MO2500 is offline
post #81 of 111 Old 07-11-2010, 08:19 PM
ALRubicon
Would you mind measuring the fairlead mount for me? I'm trying to figure out how tall it needs to be.
Thanks!
post #82 of 111 Old 07-11-2010, 09:30 PM Thread Starter
MO2500
What measurements would you like? I can get more specific ones tomorrow but my fairlead mount started as 4" wide flat bar and then the ends where slant cut down to the bumper. Fairlead mounting holes are 10" across center to center i believe.
As for fairlead height in relation to the winch, the ideal height would be so that the winch line when fed straight out horizontally goes straight through the fairlead, barely contacting the top or bottom rollers. Mine is like that on about the second layer of winch line which i believe is about what you want to aim for.
Hope that helps, and like i said if you let me know what specific measurements your looking for i'll be happy to take them for you
Instagram: @omsmike
MO2500 is offline
post #83 of 111 Old 07-23-2010, 02:46 PM
ALRubicon
Thanks for the fairlead measurements.
Did you add a tab that goes under the back sway bar bolt? I was going to have the winch plate extend to that bolt and cut it out in between the frame for clearance. Do you think that would work?
post #84 of 111 Old 07-23-2010, 07:53 PM Thread Starter
MO2500
Yea that should work fine as well, I welded on the tabs to catch the rear most sway bar bolts just because I started with an 8" wide plate and it wouldn't quite make it
Instagram: @omsmike
MO2500 is offline
post #85 of 111 Old 07-23-2010, 10:07 PM
Djay101
One thing jeep has made a mistake is not designing a rad protector for the big holes in the front on the grill... made my own...
""" Its a jeep thing, you wouldn't understand!"""
""" Jeep... is it in you? """
my build thread...
Djay101 is offline
post #86 of 111 Old 11-04-2010, 12:30 PM
Mickele_YJ
pretty boss
Mickele_YJ is offline
post #87 of 111 Old 11-04-2010, 02:13 PM Thread Starter
MO2500
Originally Posted by Mickele_YJ View Post
pretty boss
Thank you
Instagram: @omsmike
MO2500 is offline
post #88 of 111 Old 11-29-2010, 09:13 PM
hookedupinc
Come on man... you were suppose to be building the rear this summer.... Where's it at?
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
http://www.jeepforum.com/forum/f12/project-jevy-984905/
hookedupinc is offline
post #89 of 111 Old 11-29-2010, 09:33 PM Thread Starter
MO2500
I did Here is the link Rear crossmember build
Instagram: @omsmike
MO2500 is offline
post #90 of 111 Old 11-29-2010, 10:12 PM
hookedupinc
Sweet man... I like it... I have never seen another one like it... good job!
Winch, Bumper, Mounting Plate, Lights, Front End Stuff zener6 General Jeep & Off-Road Equipment 3 08-18-2011 04:52 PM
My Front Winch Bumper Build Thread redhatman Fabrication Shop 90 05-13-2010 07:38 PM
Front bumper, Grille Guard, & Winch Plate Hobojo General Jeep & Off-Road Equipment 2 10-13-2009 12:47 PM
winch plate for the new bumper Siphon General Jeep & Off-Road Equipment 1 07-05-2009 06:52 PM
winch in front too heavy njrealtor55 General Jeep & Off-Road Equipment 4 02-25-2004 07:30 AM
