Quantcast Front Bumper/Winch Plate Build! (pic heavy) - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Front Bumper/Winch Plate Build! (pic heavy)
Old 12-26-2009, 08:49 PM   #1
MO2500
Fabramicator
MO2500's Avatar
Started building this bumper a few weeks ago and now its almost finished (need paint). This is the first thing i'v fabricated for the jeep since i bought my welder a few months ago so sorry for all the pics. i'm happy with the way it came out All done with Hobart 187 and an angle grinder (man do i want a plasma cutter, chop saw, and drill press now! )
Let me know what you all think. i'll run you through the build...
First, this is the steel i started with, 2x4" 3/16 thick rectangle for the bumper and 1/4" plate for the top and winch/fairlead mount
Cut the ends at the angle i wanted and also cut the holes for my shackle mounts that are welded on both sides of the bumper.
Shackles welded in place
Then tacked and welded the end caps in place
Finished end after grinding and smoothing with a flap disc
Tacked the top plate to the bumper while fitting everything to the frame
Thats how the bumper sat for the last few weeks while i waited for this
Now i could continue working on the winch and fairlead mount. Started fitting this together
Tacked into place
placed the winch and roller on to make sure everything fit before burning it all in
Stitch welded the fairlead mount to the bumper and winch plate. This is the front
Back
This is just to show how i offset the welds on the front and back
Okay so that finished up the fabricating part. Here it is mounted up unpainted. Whatcha think?
My Build Thread
Useful links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Old 12-26-2009, 09:10 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That is really nice!!
How did the front winch mounting bolts work out in relation to the bumper? Are the bolts sitting over the bumper at all?
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 12-26-2009, 09:18 PM   #3
DC4W-93XJ
1990 XJ Cherokee
nice job.. why so wide?? narrow it up a bit and you'd gain lots on your approach angle..
looks good though
THIS AIN'T YOUR MAMA'S STATION WAGON!!
Built Jeep Tough With Chevy Stuff
"Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s
SEE THE BUILD HERE
DC4W-93XJ is offline   Reply With Quote
Old 12-26-2009, 09:21 PM   #4
MO2500
Fabramicator
MO2500's Avatar
Thanks
good catch, the front bolt holes for the winch feet ended up right at the back of the rectangular tube. i had to notch the tube just alittle bit to clear the bolt head so i could get a wrench on it. It was a tight fit, i couldnt move the winch back because of my stock sway bar and also wanted to keep from moving the bumper forward any
My Build Thread
Useful links:
Driveline 101
TJ Specs
-Mike-
Old 12-26-2009, 09:23 PM   #5
elpound
Junior Member
elpound's Avatar
Great job on your bumper! Looks real professional
elpound is offline   Reply With Quote
Old 12-26-2009, 09:25 PM   #6
MO2500
Fabramicator
MO2500's Avatar
looks good though
I actually like the 48" wide look. i mostly did it to protect the front end while i still have the stock fenders. i figure i could always chop the ends off later down the road when i go tube fenders
My Build Thread
Useful links:
Driveline 101
TJ Specs
-Mike-
Old 12-26-2009, 09:32 PM   #7
csail168516
wow! that looks awesome! i've been wanting to build my a front bumper as well. if you don't mind me asking what did the materials cost you?
csail168516 is offline   Reply With Quote
Old 12-26-2009, 09:50 PM   #8
MO2500
Fabramicator
MO2500's Avatar
Thanks for the compliments guys! i had a lot of fun building it
I think i spent around $120 for everything. i feel like thats pretty good since i got a new bumper and winch plate all in one! you know the price of those if you buy them Although, the steel could probably be found cheaper than the local place i got mine since they tend to charge a lot for small pieces
My Build Thread
Useful links:
Driveline 101
TJ Specs
-Mike-
Old 12-27-2009, 05:11 PM   #9
MO2500
Fabramicator
MO2500's Avatar
Well i had the heaters running all day and shot some paint. A few coats of self etch primer and then Krylon satin black. Now its inside curing.
I'll get a few shots after i get it all put back together. Hopefully i have some time tomorrow.
My Build Thread
Useful links:
Driveline 101
TJ Specs
-Mike-
Old 12-27-2009, 05:46 PM   #10
dwilliamsceg
Nice work. Looks great.
dwilliamsceg is offline   Reply With Quote
Old 12-28-2009, 12:25 AM   #11
csail168516
i'd say for $120 thats pretty kick ***!
Old 12-28-2009, 11:42 AM   #12
sebastian22
Go Kings Go!
sebastian22's Avatar
Looks awesome! great job.
sebastian22 is offline   Reply With Quote
Old 12-28-2009, 04:29 PM   #13
MO2500
Fabramicator
MO2500's Avatar
Well, got it all put back together this afternoon.
I'm really proud of the way it came out being my first project. Everything fits and looks better than i expected.
Here is the finished product. Thanks for the kind words guys
My Build Thread
Useful links:
Driveline 101
TJ Specs
-Mike-
Old 12-30-2009, 05:33 PM   #14
Cjensenr
Nice work!
C.
Cjensenr is offline   Reply With Quote
Old 12-30-2009, 06:45 PM   #15
flatlander757
Now in the 937
flatlander757's Avatar
Very awesome.
Man I want a 220v welder
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Check out my Youtube channel
Pictures of it wheeling at Bill's 491
And more pics from that trip here!
flatlander757 is offline   Reply With Quote
Glock Forum
