#1 | |
front bumper design
well I've had the idea to build my own front bumper but the main problem has been the design. i don't have a bender or a press, so this would all be down with limited cutting welding and grinding tools. it took me some time to figure out a design that would be easy to do with my limited tools.
this is what i have come up with ![]() ![]() its based off of jcrs bumpers, nates 4x4 winch bumper, and aj's customs. let me know what you think. i still need to design the frame tie-ins but its to dam cold to take measurements. also i could use some help with bracing/ gussets on the back side ![]()
95 green 4dr. natural pinstriping, 4.5inch lift, 33 mud terrains, not much else, but working on it front bumper 99%(need a winch), roof rack 35%, rockers 99%, rear swing out bumper 90%, trip to Ohio 0%
#2 |
that looks awesome... get ir dun
THIS AIN'T YOUR MAMA'S STATION WAGON!! Built Jeep Tough With Chevy Stuff "Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s SEE THE BUILD HERE |
#3 |
what program are you using to create these prints? this would help great with our small fab line we started.
#4 |
Really nice design. Would love to see the actual work.
#5 |
What tools do you have to build with? I built a front bumper kind of like that except it goes up on the sides so the winch sits down a little lower than the sides of the bumper. It has similar angles to yours though, which I like. I did all my cutting with a torch and cleaned the cuts with a 4.5" angle grinder. All the welds were done with my new to me Lincoln 180HD, gas shield and .030 wire. I used 3/16" plate for the entire bumper except the winch plate portion. It is 1/4". I incorporated a steering box guard into mine. Looks like yours is done that way too?
#6 |
i have a jig saw, and a circular saw... ya that sucked to cut 1/4 but w/e
its going on a cherokee so my steering box inst as exposed as you guys with tj's
#7 | ||
Its free.
_=====o000o //__l_l_,\____\,____ l_--\_l__l_/--|lllll| _.(o)_)__.(o)_)--o-)_) "Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output Pictures Build Thread "Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark Quote:
#8 |
yep, its google sketchup, and yes its free. i found it really easy to get started, more than solid works, or auto cad.
#9 |
X-Y-J-Con
looks great, do you have measurments? would like to do something like this on my new project !! also what material ? thanks
88yj-94 4.0-ax15-2004 rubicon f/r axles-4.10's-factory air lockers-33"D!ck Cepek Crushers |
#10 |
the main 6x2 is 1/4 the rest besides the tie in plates are 3/16
pm me if you want other measurements
#11 | |
on sketchup you can show the dimensions like this and post it.
(This is a rear bumper i was desgning but am pursuing other ideas (i dont have a torch so I can't redily make long cuts, so I would need to buy a bunch of specific width flat steel, and would end up with way more than I need.. I can only get 20ft sticks that I know of around here).) ![]()
#12 |
kettles, one thing i found that worked some what well for long cuts is a circular saw with a cut off wheel instead of a blade. a lot of sparks, but cuts better than a jig
#13 |
hate to revive a dead thread, but here is the outcome. its about 95% done just need to cap the ends, weld the winch plate in, some gussets, get another tow hook(autozone was out at the time) and possibly add a hoop.
![]() don't mind the booger weld. welder wasn't feeding right. its all better now ![]() ![]() thoughts on a hoop? not a stinger, but a small prerunner style
#14 |
Vendor
Your bumper really looks great. I'd move that tow hook though. In a hard pull you'll distort the top of that tubing.
Good job so far!
Aftermarket Jeep Parts www.crabtreetool.com NRA LIFE MEMBER GOD BLESS AMERICA! Please "Let every man be swift to hear, slow to speak, slow to wrath." Jim's 85 CJ7 rebuild |
#15 |
where would you recommend it then? that place seemed to be the best spot. if i need to i could just wrap the strap around the middle piece
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
