Front bumper - JeepForum.com
post #1 of 7 Old 10-30-2013, 05:33 PM Thread Starter
92yjwoolf
Front bumper
I I'm building a front bumper the wigth of the frame and I need to know what think about going with. 1/4 inch plate on top ad the rest 3/16. It will all be tig welded and also I am mounting a smittybilt xrc8000 winch and want to know if 1/4 in would be fine? It will have 6 bolts total to the frame(4 on top and 2 on bottom all grade 8)
92yjwoolf is offline
post #2 of 7 Old 10-30-2013, 06:34 PM
jasonswelding
1/4" is fine. That's what mine is.
jasonswelding is offline
post #3 of 7 Old 10-31-2013, 07:16 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
This was a 3/16" bumper/winch with the full load as well as increased angle force, 1/4" will work perfect. As a side note, your local steel shop should be able to create a small 1" uppward bend at the back side of the top piece of the bumper (nearest the grill). Shouldn't cost more than 20 bucks to have them do and it will increase the strength and rigidity significantly.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #4 of 7 Old 10-31-2013, 07:25 AM Thread Starter
92yjwoolf
That's for input guys. I went ahead and cut my top plate out of 1/4". Luckily I have a plasma cnc machine right at my finger tips. And those are all the plates going in to the bumper
post #5 of 7 Old 10-31-2013, 06:52 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you don't have the capacity to bend a lip at the rear, you can weld one in place. As mentioned, you really should have a lip to stiffen that plate. Otherwise, a hard pull will cause the plate to bow up in the center.
BESRK is offline
post #6 of 7 Old 11-05-2013, 10:30 AM Thread Starter
92yjwoolf
Just an update. Got the bumper tacked together and going to sand blast it before finish welding welding it. (Tig) still need to bend the stinger!
post #7 of 7 Old 11-06-2013, 04:51 PM
JeepFiendClub
1997 XJ Cherokee
Ive been making XJ bumpers for about a year. I use 3/16 for the shell & 1/4 for the tie ins & gussets
CREEPY FABRICATION - http://www.ebay.com/usr/creepyfabrication
JeepFiendClub is offline
