Frame question - JeepForum.com
post #1 of 9 Old 04-02-2014, 11:21 AM Thread Starter
lar308
Frame question
I've recently bought a 81 Scrambler, typical Ohio condition, the frame is toast.
So here is the question. Original jeep frames have a raised section above the axles, I assume for the upward movement of the axle. When a lift kit is installed you normally install bump stop extensions, basically doing away with the raised section of the frame. So if I build a frame do I need to have the raised section at all? Any inputs and opinions are appreciated. Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #2 of 9 Old 04-02-2014, 12:18 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hi Ron,
We "backhalved" a YJ once, for the the "kickup" we simply layed one piece of 2"x4" tubing ontop of the other pieces... it would up looking something like this..
___---__
It's a relatively easy to keep everything straight and plumb this way.
BESRK is offline
post #3 of 9 Old 04-02-2014, 12:29 PM Thread Starter
lar308
Thats another option. I also thought of cutting the angle at 45*, capping the end and moving the next piece up . ___/---\___ Just looking for ideas, by the time a cj7 frame and stretch it I'll have as much time and money in it as building one. Thanks, Ron
lar308 is offline
post #4 of 9 Old 04-02-2014, 08:09 PM
tjcj
You don't have to make the whole kick up if your making a new frame. I made a complete frame out of 2" 4" for a Willy's and it looked like this from front to back ----____---- I overlapped the front and back section over the middle section by 10" 45 cut everything capped the ends and added fish plates in side and out. Worked great. Actually got the idea from JP magazine or one of those mags.
Sent from my XT881 freeze ray gun using JeepForum.
Yakima Valley Mountaineers.
tjcj is offline
post #5 of 9 Old 04-02-2014, 09:11 PM
nacheswheelin
Research project ground up cj from jp mag.
Who ever said less is more never owned a jeep.
nacheswheelin is offline
post #6 of 9 Old 04-02-2014, 09:15 PM
tjcj
Yep that's the one.
tjcj is offline
post #7 of 9 Old 04-03-2014, 04:27 AM Thread Starter
lar308
Thanks guys, I'll pull up that article. Ron
lar308 is offline
post #8 of 9 Old 04-04-2014, 09:44 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
This is about halfway through the process.....but you see the idea. Make a template out of the sides, cut them out and weld them together. This doesn't show it, but like "back halving"...a couple "fish mouth" support pieces are welded on each side to reinforce the frame.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #9 of 9 Old 04-05-2014, 06:39 AM Thread Starter
lar308
Thanks for all the suggestions, Now the planning and then the fun begins. Ron
lar308 is offline
