FRAME FIX dont know where to start pics!! - JeepForum.com
post #1 of 21 Old 11-12-2008, 02:19 PM Thread Starter
01blackws6
How should I go about fixing this??
01blackws6 is offline
post #2 of 21 Old 11-12-2008, 02:23 PM
Exparrot
Exparrot's Avatar
I'd hate to say it, since I have some cancer back there as well, but a new frame might be in order. At the very minimum, I would back-half a better frame and replace the whole back end. I have a feeling if there's a lot more rust there than you think.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #3 of 21 Old 11-12-2008, 02:26 PM
twobit
06 Solar Yellow TJ X obtained 10-2009 with 3400 miles
99 Cherokee Sport, bought new, now @ 223,000 miles
Southwest Texas
twobit is offline
post #4 of 21 Old 11-12-2008, 03:21 PM
BlackBellamy
BlackBellamy's Avatar
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #5 of 21 Old 11-12-2008, 03:42 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
maybe try a search?
http://www.jeepforum.com/forum/searc...archid=3235064
it can and has been done plenty of times, but as already said, you probably have more rust than what you are seeing right there.
as a hint, make sure you drill a 1/2" hole at the bottom of the lowest part on that section if you repair or get a new frame. it is a water trap!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #6 of 21 Old 11-12-2008, 04:30 PM
mcneil
Yeah, probably going to have to go pretty far forward on the frame to find something solid enough to weld to.
More pictures?
mcneil is offline
post #7 of 21 Old 11-12-2008, 09:14 PM
harley2003rkc
Mine looked like that when I started my rebuild. I went and bought some 3"x3"x3/16" tube steel, and rebuilt from the rear hoops back. I chose the 3/16" because the ID of the 3" tube matched the OD on the width of the frame. Which when I cut off the top and botton of the tube, left me about 8" of the tube sides to match up on the frame and give me a good strong transition into the new tube. I found it to be extremely close in the height of the original frame, and 3/16" wider on each side. I'll post pics if I have time before leaving for deer camp friday.
harley2003rkc is offline
post #8 of 21 Old 11-12-2008, 10:18 PM
Lifesgoodhere
Originally Posted by BlackBellamy View Post
dude im wearing that shirt RIGHT NOW
A Jeeper for life
Lifesgoodhere is offline
post #9 of 21 Old 11-13-2008, 06:48 AM
1 ton yj
1 ton yj's Avatar
Best way to do it is to cut a peice out of a good frame and weld it in. All of the comercially availible kits I've seen are like putting a bandaid on skin cancer, they just cover it up and don't get rid of it.
1 ton yj is offline
post #10 of 21 Old 11-13-2008, 02:21 PM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
You're going to have to see how far that cancer has reached. If it's that bad there, it's probably affected other components than just your frame such as your body and mounts, gas tank skid, muffler, etc. Oh and make sure your Tetnus shot is up to date!! (every 10 years) If your not experienced at fabrication the easiest route would be to find a wrecked YJ with no frame damage and swap out the frame. Keep us posted on what you decide!
FunkSkunk is offline
post #11 of 21 Old 11-13-2008, 02:23 PM
FunkSkunk
FunkSkunk's Avatar
oh and DONT DRIVE IT ANYWHERE!!
post #12 of 21 Old 11-13-2008, 02:26 PM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
It's an easy fix. Is that the only place you have it? I have to tell you DON'T DRIVE IT. Your about to lose your axle because of that shackle
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off)
TrailWorthyFab is offline
post #13 of 21 Old 11-13-2008, 02:26 PM
prjohnson
WOW! How old is that car?!
prjohnson is offline
post #14 of 21 Old 11-13-2008, 02:26 PM
JeepMKcomin
bondo it?
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #15 of 21 Old 11-13-2008, 02:27 PM
TrailWorthyFab
TrailWorthyFab.com
Do something like this. Cut the frame back to where it is good and clean
Get you some new 2x4 square tube and weld it to where you made your cut
Cut you some fish plate
Grind your weld from the old frame to the new smooth.
Front shackle mounts tied into frame (pics) webdr Fabrication Shop 7 07-02-2010 06:58 AM
Wanted Pics of frame mounted rock rails TJ-Marine PA Fabrication Shop 18 05-23-2007 08:34 AM
I want a stroker but dont know where to start! kevin2236 Engines & Drivetrain 10 01-25-2007 04:38 PM
83 CJ5 Renegade frame-off pics Shameless Elmer General Jeep & Off-Road Equipment 2 09-06-2006 04:53 AM
Pics of YJ tire carrier mount to FRAME??? FunkSkunk Fabrication Shop 4 09-15-2003 06:14 AM
