ford dana 60 in cj5 - JeepForum.com
post #1 of 3 Old 07-13-2010, 09:02 PM Thread Starter
matt1982
1978 CJ5
ford dana 60 in cj5
LI have a 78 cj 5 and I want to run the 60 I have out of a 1 ton ford in the front but the center section is on the drivers side on the ford can I flip it and run a reverse gear I'm new to the off road stuff could somebody give me some advice please thank u
matt1982 is offline
post #2 of 3 Old 07-14-2010, 06:19 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nope.. can't flip it. It'll run backwards. Your best bet would be to sell it and pick up a GM D60. Next option would be to retube it to move the center section.. but that could be kind of pricey.
I read an article once where someone just cut the knuckles off, cut the tubes, bevelled the ends, turned a tight fitting inner sleeve on the lathe, sleeved/rewelded the tubes in place on opposite sides (long/short side) and then rewelded the knuckles in place. Between the inner sleeve and the bevelled joint, the tubes were said to be plenty strong.
I've got another buddy who used an air-arc to blast out the plug welds at the pumpkin (this was on a rear D60) and built himself a simple press to pull the axle tubes out of the housing (seem to remember him saying it took about 30tons of force). He then swapped tubes from side to side and pressed them back in place.
BESRK is offline
post #3 of 3 Old 07-14-2010, 08:07 AM Thread Starter
matt1982
1978 CJ5
Thanks for the info
matt1982 is offline
cj5 , dana 60 , ford , swap
96 Ford Dana 60 in a 97 XJ tjjeepwrench978 Fabrication Shop 2 09-02-2009 09:27 PM
Dana 60 Vs Ford 8.8 DARRTILLM Engines & Drivetrain 2 10-08-2008 01:53 PM
Ford Dana 44 vs Jeep Dana 44.. ((~JEEP~)) General Jeep & Off-Road Equipment 7 07-15-2007 03:34 PM
What can you tell me about the Ford 10.5 / Dana 50 / and Ford Excursion? SPL Tech Engines & Drivetrain 15 01-10-2007 07:01 AM
ford dana 44 aussie stu Engines & Drivetrain 9 12-16-2006 08:30 PM
