Floor panel - JeepForum.com
post #1 of 8 Old 12-24-2013, 07:09 PM Thread Starter
Zyurazek
Floor panel
Today I lifted up my carpet in the YJ and found a large area of rust in the driver side front floor panel. Would anyone be able to tell me how difficult it is to put in a new floor panel? What kind of welder I could use? I have never done any sort of welding before, but I am handy when it comes to making cuts and I learn quickly. Any pointers? I will try to upload a picture of the area.
Zyurazek is offline
post #2 of 8 Old 12-25-2013, 03:23 AM
AGDubyaJ
Thats a pretty major welding project to take on with limited experience. Your gonna need a small MIG welder or oxy-acetylene rig to weld it up- $$$, not to mention, welding RUSTED thin gauge steel is not easy, even for lots of experienced welders/fabricators. you could always just get some thin gauge steel or aluminum, cut to shape, rivet in, and seal with silicon or the likes. Would probably be easier and more cost effective... Not saying you shouldnt learn to weld, a decent 110V mig welder can be had for around $400... and thats going to limit you to 1/4" material. On top of the welder, your still gonna need a helmet, gloves, angle grinder and wheels, welding wire, gas, and consumables... definitely not a cheap hobby to get into.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #3 of 8 Old 12-25-2013, 07:17 AM
Ironworker709
Ironworker709's Avatar
Find a local jeep or 4x4 club,there will be people there that has capabilities and equipment to weld a new panel in and you'll also gain some new freinds.
You can also buy a replacement pan just for that part and use a panel adhesive like 3M makes...
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 8 Old 12-25-2013, 08:43 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
What he said....
http://www.quadratec.com/products/22...FSEV7AodH2cAvA
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #5 of 8 Old 12-25-2013, 05:40 PM Thread Starter
Zyurazek
Would you be able to get away with just a panel adhesive for that much?
Before putting the panel down, should I cut away the rusted spots?
Zyurazek is offline
post #6 of 8 Old 12-26-2013, 07:13 AM
thantos858
1974 CJ5
Remove as much of the rust as possible then use a treatment like por 15. If done right adhesives can be used for larger sections. A lot of newer cars use more adhesives than welding to hold them together.
thantos858 is offline
post #7 of 8 Old 12-26-2013, 10:11 AM
Ironworker709
Panel adhesive is regularly used for full 1/4 panels,door skins,,trunk floors,,,etc etc...so yes..it is more than good enough for your repair and will hold for the lifetime of the vehicle if done right.
2 other things needed to buy before you do the chore...
1 TEK screws..or aka self tap sheet metal screws..these will be used to hold the new panel tighly and firmly in pace until the adhesive cures
2 "Seam sealer"..don't mistake a seam sealer for a panel adhesive...this will be used to fill the little holes from the TEK screws and used to insure a total sealed edge on the new panel on top and bottom side..both the adhesive and sealer are paintable..
Lay your new panel over the area where it will be replacing the old rusted area..draw a line around where it sit flat in there...take the new panel back out..
Measure down at least 1 inch and draw a line below where your current line is..this will be your cut line and give a good surface for the adhesive to bond to...
Cut the old rusted panel out along the lower line..
Sand that area to bare metal and CLEAN over and over..use acetone or MEK..Naptha..etc..a good solvent to insure no contaniments are there to inhibit the bond...
Lay your panel in where it will go for a mock up to make sure it fits snug on all the edges...if all looks fine..your ready for the panel replacement...
Run about a 1/4 inch bead of the adhesive either on the floor edge or the panel edge..in about a 1/2" or so from the edge of the panel..or 1/2" up from the edge on the floor area..
Lay your new panel in place..use your TEK screws to to screw the new panel in place all around the edge about a 1/2" down from the edge every few inches to make sure the panel is snug all the way around in place..do not tighten them so much it smashes the panel so tight it pushes all the panel adhesive all the way out..you want a very small gap between the 2..about a 32nd or 1/16th or so ...
Once all done and satisfied with the fitment..use a putty knife to remove all the access adhesive around the edge to make sanding later much easier and a better appearance...
Let sit for 24 hours or more..or whatever the adhesive manufacturer recommends according to the temperature it was applied...
Once cured..remove the TEK screws..now use the seam sealer to fill the holes from the screws..top side and under side..i would also use the seam sealer to put around all the edges on top and bottom side for extra insurance of a good seal...
Your done...good primer..then paint or bedliner or whatever you decide on...
I would only use the 3M adhesive...there is alot of "knocks offs" but the 3M is the best out there hands down and you wouldn;t problems from a cheaper brand surfacing later down the road...
For some instructions and pics to see what is involved and how easy it really is...do a google search for "Panel adhesive new floorpans"..plety of people that did it with write ups on it
Never forget 9/11
post #8 of 8 Old 12-30-2013, 08:31 PM Thread Starter
Zyurazek
Thank you! That is great information!!! If I wanted to replace the panel under the seat after it replace this panel, can I use the same technique although it will be connecting to the panel currently being replaced?
Zyurazek is offline
