flip up winch mounted license plate bracket - JeepForum.com
post #1 of 15 Old 12-04-2009, 01:48 PM Thread Starter
dukegnarley
I wanted to move my license plate from the stock location on the front bumper up to where the winch fairlead is so it wouldn't get bashed up as much. I also wanted to make it harder to steal than just having it clipped to the rollers. I saw the Tough stuff license plate holder and liked it.... Until I saw the $70 + shipping price tag. Seriously? $70 for a license plate holder?
Here's how you can make your own.
I got everything I needed from Home depot except for the sheet metal which I got from another local hardware chain.
you will need:
2x 1-1/2" conduit hangers ($0.67 each at Home Depot)
2x Safety Hasps, about 4 inches long each ($4.59 each at Home Depot)
1 piece of sheet metal at least 12"x6" I got a 16 ga 18" x6" piece from the hardware store for $7.50 ish
4 1/4-20 nuts and 4 bolts ($0.98 total at Home depot)
you will also need some paint, but you probably have that already.
grand total (minus paint) = $19
Step 1.
bend the conduit hangers until they look like this. you will have to cut some of the ends off to make it work (stock on left, bent on right)
some people use mag light clips, but they are more expensive
make sure they fit.
Step 2
get out your Saftey Hasps and discard the portion that holds the lock. When you buy your hasps, make sure that they are made of flat metal and don't have ridges.
If you are using the same hasps I am, then make a mark in the middle of the small section, 5/8" away from the edge. (bottom in this pic)
Center punch it and drill it out to 5/8"
Step 3
mark a line on the hasp 1-7/8" away from the hinge.
place the hasp into a vice up to the line, then bend it 90 degrees. Make sure you bend it the right way.
Step 4.
Remove the retaining clips holding in the pins on your roller fairlead, and install the bent up hasps. Replace the clips.
Step 5.
Trace out your license plate on your sheet metal, then cut it out.
Step 6.
Tack weld (or screw or rivet) the sheet metal to the hasps. I used the top of the winch plate to make sure everything was straight.
check for clearances
Then add a few more tacks to make it solid. Flip it down and tack on the clips you made earlier.
Step 7
use your license plate as a template and mark hole locations.
drill them out to 1/4", and attach your license plate with the 1/4" hardware you bought earlier.
Now you are almost done, just check your clearances once more, then take it apart and paint it.
Step 8
Take the $51 dollars plus shipping you saved, and put it towards a new bumper.
Unlimited Length YJ "Sasquatch"
Renix 4.0
AW4 swap with
= DONE
dukegnarley is offline
post #2 of 15 Old 12-04-2009, 01:53 PM
XJisTHErightWAY
You sir are a saint. You just saved me $30 Yours look nicer than the one I was looking at on Quadratec. Cheap little pop off holder. Nicely done sir.
I had a hot girl on facebook say "nice jeep, but i've always wanted a wrangler" and my response was deleting her from my friends list.
XJisTHErightWAY is offline
post #3 of 15 Old 12-04-2009, 01:58 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Nicely done! Another way to get the license plate off the bumper but easily removeable is to mount the plate to a piece of sheet metal and screw a pair of $5 Mag-Lite D-Cell flashlight holder clips to it. The clips fit the winch fairlead rollers perfectly and allow the license plate to be unsnapped & snapped back into place. That's how I have had mine mounted for years.
Jerry Bransford is offline
post #4 of 15 Old 12-04-2009, 02:28 PM Thread Starter
dukegnarley
I was looking into that, as it is also very cheap to do, but I wanted to keep the license plate permanently attached. I have a bad habit of misplacing things when they aren't tied down some how. This makes it a little less likely to be stolen, although I'm not sure if anyone would.
Renix 4.0
AW4 swap with
= DONE
post #5 of 15 Old 12-04-2009, 03:11 PM
footinmouth47
footinmouth47's Avatar
Thank you for this write up unfortunatly now I have one more thing I NEED to make.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #6 of 15 Old 12-04-2009, 06:10 PM
kercher
kercher's Avatar
really nice. i like how it is solid mounted as opposed to just "snap on" & "snap off".
kercher is offline
post #7 of 15 Old 07-22-2012, 11:13 PM
ajones8230
Love it! I'll be heading to the depot this weekend to pickup the parts and start creating my new plate mount. Thanks for the excellent write-up!
ajones8230 is offline
post #8 of 15 Old 07-23-2012, 05:01 PM
tangotag
Nice bump, this project is now on the short list things to do soon.
tangotag is offline
post #9 of 15 Old 07-23-2012, 08:34 PM
1999TJRED85000
Nice job. I know this is an older thread, but I just read it. Nice.
F U
1999TJRED85000 is offline
post #10 of 15 Old 07-23-2012, 11:27 PM
MaddogMedic
you will need:
Step 1.
make sure they fit.
Step 2
Step 3
Step 4.
Step 5.
Step 6.
Step 7
Step 8
Very Nice Job
MaddogMedic is offline
post #11 of 15 Old 07-27-2012, 06:04 PM
ajones8230
Built it today! A little difficulty with the pins not being long enough after the hasps went through them, but we ground down the roller bracket some to get the c-clips back on. Fun project with my son and much cheaper than $70 and shipping. We spent $22 at the depot.
post #12 of 15 Old 07-28-2012, 02:46 PM
tjcj
heres howI did mine. Drilled and tapped fairlead, bolted a hinge to them, epoxied magnets to the back. Total cost less than $5
Yakima Valley Mountaineers.
tjcj is online now
post #13 of 15 Old 07-28-2012, 03:19 PM
ajones8230
Very cool. An easier an cheaper method... Always a day late ;-)
post #14 of 15 Old 07-29-2012, 02:21 AM
Burlbook48
Burlbook48's Avatar
Not to take away from a neat idea (or an old thread) but... what stops the plate from falling down and getting FUBARed and/or damaging the cable while reeling in the winch and the vehicle is moving over rough terrain?
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #15 of 15 Old 07-29-2012, 08:58 AM
tjcj
I had the same set up on my CJ for over 5 years, been on the TJ for over a year. Never had any problems with it damaging the cable. It does fall down sometimes. Once I go to synthetic rope I will probely do something diiferent.
tjcj is online now
relocating license plate thisgardengrove Fabrication Shop 5 07-16-2009 09:18 AM
License Plate Magnets bgoman General Jeep & Off-Road Equipment 7 03-19-2009 12:36 PM
Anyone installed the ORO/Rock Hard LED & license plate bracket ROUGHSHOD Audio, CB & Ham Radios, GPS, & Electrical 7 10-25-2006 07:40 PM
License plate light Rocky529 Audio, CB & Ham Radios, GPS, & Electrical 2 08-29-2005 10:36 AM
license plate ideas steelerman General Jeep & Off-Road Equipment 19 08-07-2004 09:39 PM
