Flattening a pice of tube - JeepForum.com
post #1 of 11 Old 01-21-2012, 07:27 PM Thread Starter
attackcammel
Hey guys I want to put a stinger on my stubby bumper I buit. I don't want to put the stinger on the front because i think it will look too crowded when I get the winch and fair lead on. So I was thinking of flattening the ends of the tube and welding it to the sides of the bumper.
How much do you guys think this would compromise the strength of the tube?
What do you think the best way to flatten the tube would be?
I'll try and get some pics or at least a sketch of what I'm talkin about. Just give me a little while and I'll get one up
Originally Posted by Hilldweller View Post
Ordinary cars lie to you. They tell you that everything is controlled, warm, safe, smooth ---- we know this is a general falsehood. There is extreme beauty in the world and the best way to find it is to be out in it --- all the way. In a Jeep. Cause you can't get there in a Camry.
attackcammel is offline
post #2 of 11 Old 01-21-2012, 07:31 PM
Serg5000
Why flatten the tubing? Why not just cut and weld.
Serg5000 is offline
post #3 of 11 Old 01-21-2012, 07:33 PM Thread Starter
attackcammel
I think it would look goofy With the tube just sitting on the side of the bumper
post #4 of 11 Old 01-21-2012, 09:19 PM
hndswthtshdws
If you flatten the tube it will be much easier to bend at the flattened part.
hndswthtshdws is offline
post #5 of 11 Old 01-21-2012, 10:53 PM Thread Starter
attackcammel
But the bend at the point of the stinger would triangulate it and keep the strength right?
post #6 of 11 Old 01-21-2012, 11:27 PM
MO2500
Do you want the stinger to look cool or actually function and possibly prevent a front endo? Serious question because a lot of stingers are built for the "look" of a stinger and are not as functional as people think they are.
If you can answer that question you probably already know the answer. If it's going to be somewhat functional then don't compromise the strength of the tube by flattening it.
Instagram: @omsmike
MO2500 is offline
post #7 of 11 Old 01-22-2012, 12:54 AM
rdsk8ter
1982 CJ7
weld plate at angles off of it and smooth it out it'll look cleaner then if that's what "look" your trying to get
here is my build threads
http://www.jeepforum.com/forum/f104/randys-offroad-trailer-1164102/
rdsk8ter is offline
post #8 of 11 Old 01-22-2012, 03:33 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Notch halfway into the tube. Have about 1/2 the tube sit on the top of the bumper with the remaining half running down the side. If you make the long vertical tapered, you can pound the end in carefully to give it a cleaner look..
Here's a cheesy Paint drawing of what I mean..
BESRK is offline
post #9 of 11 Old 01-22-2012, 04:26 PM
Abaddon
1995 XJ Cherokee
I agree with Besrk cut it to fit dont smash it. If you dont want the tube to sit on top of the bumper at all then cope it so it fits the side.
Not only will smashing it cause a weak spot but it will look worse then you think.
However if your just bent on smashing the tube and doing it your way either heat it and clamp it in a vice or heat it and use a hammer on an anvil
The heat will also cause a weaker spot as your probably going to have to heat it red hot then weld it adding more heat and while heating it your traping gases inside the steel causeing pockets to form. These pockets will cause the steel to split under stress. This is the reason welding uses a sheild gas or flux. A luxury you dont have when heating a peice of steel.
You maybe able to do it with out heat using the hammer and anvil but be prepared to work for it and in either case if your seam weld in the tube is to the side instead of the bottom of the bends and inside of the smashed area expect it to split.
This stuff may not always happen but it is the cons of doing it with out any real pros.
Anyway just an old welders rule of thumb good luck in either case
Abaddon is offline
post #10 of 11 Old 01-22-2012, 05:07 PM Thread Starter
attackcammel
It's probably more for looks but I still like things input on the jeep to have some kind of function even of I don't use it all of the time. When joust cope it to fit on the sides are you saying to cut it down lengthwise with the tube? I might have to look at that
post #11 of 11 Old 01-22-2012, 05:09 PM Thread Starter
attackcammel
Beserk I think I'm liking that idea that Is pro only what I'll use
Inner Tube Won't Go?? kellymc Tires & Wheels 8 02-26-2011 09:44 PM
What is the difference between a tube bender and a tube roller mudcrawler90 Fabrication Shop 6 01-24-2010 01:30 AM
What kind of tube bender for tube bumper build? PeriwinkleZJ Fabrication Shop 12 11-01-2009 01:07 PM
Mono Tube/Twin Tube suspension Lemmiwinks General Jeep & Off-Road Equipment 0 06-09-2009 08:27 PM
$15 Sub Tube - Not Bad kdavis Audio, CB & Ham Radios, GPS, & Electrical 1 05-24-2004 04:44 PM
