Flat TC skid - Page 6 - JeepForum.com
post #76 of 80 Old 05-17-2007, 06:14 AM
Scotch740
Scotch740's Avatar
Originally Posted by KellyF
You can bend the tub by placing a small spacer between the TC and the tub and then jacking the TC up. I was able to gain some clearence by doing this. The TC would hit the tub when I was in high torque. I was able to flat pan a Rubicon. I did have to put in a CV driveshaft and relocate the shifter + 1 1/4" Bodylift. Biggest trouble I had with a flat pan was the heat would build up. I eventually lowered it 5/8" to allow for more air flow.
Kelly
How did you know you had a problem with heat, floor melting you boots? I'm assuming your referring to the exhaust.
Scotch740 is offline
post #77 of 80 Old 05-17-2007, 08:55 PM
KellyF
Yes the exhaust was the heat problem, the floor would get so hot that you could hardly touch it, so I figured that the TC and Trans were getting hot also.
It didn't help that I also have the engine and trans plated too.
Kelly
KellyF is offline
post #78 of 80 Old 05-20-2007, 08:08 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I built mine for about $60.
1/4" thick with gussets across. i'm going to cut the back half off to cut down on weight and because it's not needed. Also, I have taken the TC drop out of it, but I'm getting some vibes and so i'm going to need to do something about that. I also modified the Exhaust hanger where it meets the tranny mount.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #79 of 80 Old 05-21-2007, 07:00 AM
Scotch740
Scotch740's Avatar
How exactly did you modify the exhaust hanger? My plan is to cut a 1" or how ever much I need out then bolt/weld a bracket to the two pieces to join them.
post #80 of 80 Old 10-08-2009, 07:22 PM
Boodyrider
Originally Posted by Dave Taylor View Post
OK....TJ Jeepers.....
Can anyone confirm if this YJ skidplate mod will work with a TJ.
Assuming a 1" body lift and 1" motor mount lift; along with SYE, CV-shaft, etc....
Is it as simple for the TJ as it is with the YJ.....
Cut out the tranny mount hole; and the front shaft hole; move the tranny mount over; drill the frame-rail holes...and go flat-belly?
on TJ, at least a 97:
Dead flat to the frame won't fit under the body due to the transfer case shifter linkage, even with the AA adapters bracket. It also depends on whether you want to have a separate trans support. Flat to frame would also likely require clocking the transfer case as a corner of the tcase hand noticably below the bottom ot the trans mount,
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
My flat skid build PBR Fabrication Shop 71 10-09-2009 01:05 PM
Bracing flat TC skid Scotch740 Fabrication Shop 16 10-09-2009 06:07 AM
Gas Tank Skid/Flat Belly Skid Stan99 Fabrication Shop 18 01-23-2009 11:06 PM
How to flat skid? PBR Fabrication Shop 5 07-07-2008 07:21 PM
Flat Pan Skid Plate...FOR TJs Viet15philong Fabrication Shop 11 10-12-2005 05:35 AM
