Flat TC skid - Page 5 - JeepForum.com
post #61 of 80 Old 01-25-2006, 07:51 PM
HOOTIE
Originally Posted by tommaho
Did you install a tc shift relo bracket? If so, which one and how much clearance did it give you?
No I did not install a shift relo bracket. I hav'nt had any problems with the shifter.
2004 TJ X, RED, 5- Speed, Ecco Wheel Package, Detroit TRUE-TRACS Both ends. 2" lift,1" BL,1"MML, Rancho 9000X shocks, Warn M12000# winch, 31"x10.50" BFG MT'S. Homemade Flat T.C. Skid,SYE, Rock-It-Man Ultimate Rockers
HOOTIE is offline
post #62 of 80 Old 01-28-2006, 07:28 PM
tommaho
tommaho's Avatar
Has anyone with a completely flat skid run in to issues with the DS operating angles and needed grind work or a special shaft? If so, how much lift are you running?
Tom
tommaho is offline
post #63 of 80 Old 02-02-2006, 12:57 AM
Muddy Tj Zack
Ok, I wanna do this with just a 1" BL. I think with some time I can get it to fit fine, but my question is how bad will it throw off the angle of the drivetrain and will it mess me up?
'97 Tj Sport, 4.6L Stroker, 5-Speed, 4-in suspension lift, 35" TrXus M/t's, Dana30/Ford 8.8 w/ Aussie Locker, Teraflex ExtremeShort SYE, custom front and rear bumpers, Flowmaster Off-road Series, and a bunch of other goodies........MoPar or No-Car!!!
Muddy Tj Zack is offline
post #64 of 80 Old 02-02-2006, 09:13 AM
rsm688
Originally Posted by HOOTIE
If I were to do it again, I would use 1/4" plate because I had to brace the 5/16" to stop it from flexing. The 1/2" pieces are welded in.
ummm...isnt 1/4" smaller than 5/16"? since 1/4" is the same as 4/16"?
04 TJ Columbia Edition with some junk in the trunk
rsm688 is offline
post #65 of 80 Old 02-02-2006, 09:18 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
yes, but since even the thicker plate had to be braced you could use the slightly thinner material and save some weight. at least that's how i read that
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #66 of 80 Old 06-11-2006, 09:50 AM
tommaho
tommaho's Avatar
To keep the flat skid fab notes in this thread...
I'm currently working on mine - 1/4 with a single 1 1/5" x 3/16" angle welded across the center for support. Camera's down, so pics are coming as soon as they're developed.
There must be some differences with the 2003+ 42RLE trans, because there is NO room above the bellhousing*. I clearanced the area directly above the top boss cast into the housing along with the areas above the left rear part of the TC and directly above the output shaft. I still need to drop the skid 1" or so.
Note I didn't pull the trans and transfer case, which is the only way to do it right and make enough room for the flat skid.
Also, the skyjacker bracket is great, it's nowhere near the tub.
*My setup:
1.25" BL
1" MML
Tera ESS SYE
Adjustable Arms
More notes to follow.
Tom
[Edit:]
Well, I guess I spoke too soon. I was able to get the skid on with no drop.
There's still some interference between the tunnel and bellhousing, so there's a minor vibe. I'll have to either work over the tub some more in that area or just drop the skid with a couple washers.
I don't have many pics, but will try to put together a more detailed writeup.
tommaho is offline
post #67 of 80 Old 10-08-2006, 09:59 PM
pasadena
pasadena's Avatar
anymore on this? id like to see some pics, i think im going to build somthing like this on my rig...
pasadena is offline
post #68 of 80 Old 05-09-2007, 05:52 PM
highrisetj39.5
i wanna make one
2000 Tj 4.7L supercharged, with a nv3500 and SYE np231. Currie Hp 9"s w/ 4.56 and arbs, rubicon express 4.5" SF, 1" BL, 35" BFG M/T, warn m8000, all custom armor, cage and bumpers front and rear with tire swing away, CB, Currie HD steering, and some other things
highrisetj39.5 is offline
post #69 of 80 Old 05-10-2007, 09:34 AM
tommaho
tommaho's Avatar
There are some pics in this thread of how I set mine up:
http://www.jeepforum.com/forum/f37/tc-crossmember-fab-wrangler-355186/
I actually ended up dropping mine back down for exhaust clearance and to smooth out the transition between my belly and low-hanging Clayton arm brackets. I don't have any new pics of that setup.
Tom
tommaho is offline
post #70 of 80 Old 05-11-2007, 07:21 AM
Scotch740
Scotch740's Avatar
I am in the process of designing a flat skid for my stock unlimited. First I am making a BMML the adding a 1.25" BL. I will then see how high I can raise my T case and trans with out contacting the tub. Can anyone comment on me doing this WITH OUT a SYE and CV? Keeping in mind I have a stock height Unlimited. I think I will have to add the SYE when I put on a lift next summer or when ever that time comes, but I would be doing that anyways. As for now I think I will be fine.
Scotch740 is offline
post #71 of 80 Old 05-11-2007, 09:38 AM
bairy
I have a 4" lift on my unlimited and when I put on the clayton skid, the driveshaft was long enough, but was getting short. With my Clayton skid on, and no BL, the transfer case did not hit the body, but the Round cat of my 06 and the Cat exhaust hanger did hit the tub. I can either put a BL on there, or do some exhaust work. After a 4" lift and a TT, a SYE is needed on the LJ.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #72 of 80 Old 05-11-2007, 10:28 AM
Scotch740
Scotch740's Avatar
I am thinking I would cut about 1" out of the middle of the hanger, weld it back together and weld or bolt a brace to it. I was going to have a 1" X 2" spacer tube between the skid and frame but now I am thinking I might just bolt the skid straight to the frame. If I have vibes I can add spacers until they are gone. My main concern is with the shifter mounting. I would like not to have to order a relocation bracket but whats $40 when I am saving $30 on my BMML and $250+ on the Flat Skid. Like those savings, lets me order some good rocker guards, as I'm not ready to show off my fab skills where people can see them every day
Thanks for the info on the DS
post #73 of 80 Old 05-16-2007, 06:28 PM
smurison14
could you get away with a completely flat skid without the body lift? I dont mind beating on the floor with the BFH.
smurison14 is offline
post #74 of 80 Old 05-16-2007, 09:06 PM
bairy
Problem is getting to those areas with a BFH. You might have to remove the transfer case,tranny mount, and exhaust all the way to the header.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #75 of 80 Old 05-16-2007, 11:56 PM
KellyF
You can bend the tub by placing a small spacer between the TC and the tub and then jacking the TC up. I was able to gain some clearence by doing this. The TC would hit the tub when I was in high torque. I was able to flat pan a Rubicon. I did have to put in a CV driveshaft and relocate the shifter + 1 1/4" Bodylift. Biggest trouble I had with a flat pan was the heat would build up. I eventually lowered it 5/8" to allow for more air flow.
Kelly
KellyF is offline
My flat skid build PBR Fabrication Shop 71 10-09-2009 02:05 PM
Bracing flat TC skid Scotch740 Fabrication Shop 16 10-09-2009 07:07 AM
Gas Tank Skid/Flat Belly Skid Stan99 Fabrication Shop 18 01-24-2009 12:06 AM
How to flat skid? PBR Fabrication Shop 5 07-07-2008 08:21 PM
Flat Pan Skid Plate...FOR TJs Viet15philong Fabrication Shop 11 10-12-2005 06:35 AM
