Flat skid center mounting holes - JeepForum.com
post #1 of 9 Old 01-17-2011, 05:12 PM Thread Starter
JJeeper09
So i have a skid cut from 1/4 inch steel and all i have left is the center mount.
I will be using a low pro mount and the skid will be completely flat.
Does anyone have a measurement for the stock trans mounting holes or any way to do this easier? Here is a picture of the mount and skid
JJeeper09 is offline
post #2 of 9 Old 01-18-2011, 03:42 PM
Griff97
Were you asking me for the bolt pattern on the trans itself in my 8.8 build post? If so, I misunderstood you. Which trans? I can pull the dimensions off the bottom of an ax5 or an nv3550 if you need them.
Griff97 is offline
post #3 of 9 Old 01-18-2011, 05:04 PM Thread Starter
JJeeper09
The bolt pattern for the t-case skid, so it is the transmission mount onto the skid. Four bolt holes in the middle.
Also i really like you jig idea, did you use a d 35 to get the measurements?
post #4 of 9 Old 01-18-2011, 05:07 PM Thread Starter
JJeeper09
for the middle
post #5 of 9 Old 01-18-2011, 06:29 PM
Griff97
So to make sure I'm understanding this correctly, you are trying to get the measurements for where the factory trans mount bolts into the factory skid right? If so, I can take measurements off my skid if a mount for yours is the same as a mount for a 97 2.5 ax5. Compare part numbers and let me know. I actually cut up a factory skid to get that piece out of it previously before I decided to do mine how I did.
For the jig, I built it with it bolted onto my dana 35. I drilled out some round tubing drilled out to the correct sizes for the bolts. Then, I just bolted them into the mounts and built a jig off of them.
Griff97 is offline
post #6 of 9 Old 01-18-2011, 07:34 PM Thread Starter
JJeeper09
Well i have a different trans.. I have the NV3550 so ill need that one. I just orderd a lo pro mount from under cover fab, so i think i can just use those? Also do you think adding a few washers between the frame and skid will help if i get vibes?
post #7 of 9 Old 01-18-2011, 10:17 PM
Griff97
Are you trying to do a flat skid without doing a SYE and CV driveshaft? I have the skid from an NV3550 as well. I also have the trans. If you are using undercover fab's low pro mount, it looks like you'll need to use the factory trans mount bracket but grind the edge off of it for clearance.
Griff97 is offline
post #8 of 9 Old 01-19-2011, 07:52 AM Thread Starter
JJeeper09
Yea.. All i was trying to find was the the mounting holes to allow me to recess the bolts and go completely flat
post #9 of 9 Old 01-20-2011, 09:15 PM Thread Starter
JJeeper09
Actually.. im thinking my center mount is to high any way.. Bump on how people made their center mounts
Flat TC skid Kerndone Fabrication Shop 79 10-08-2009 07:22 PM
Gas Tank Skid/Flat Belly Skid Stan99 Fabrication Shop 18 01-23-2009 11:06 PM
How to flat skid? PBR Fabrication Shop 5 07-07-2008 07:21 PM
Flat center cap for Cragar Soft 8? thejafe Tires & Wheels 3 08-29-2007 06:18 PM
speaker mounting holes dont line up ttrem Audio, CB & Ham Radios, GPS, & Electrical 3 01-31-2006 10:21 AM
