First welder, which one to buy - JeepForum.com
post #1 of 16 Old 04-28-2013, 02:54 PM Thread Starter
79CJ7dude
1979 CJ7
So I'm wanting to buy a cheap welder to learn on, and I'm looking at 90 amp flux wire welder from harbor freight and the northern tool flux core 125 115v. Which one would be better for a beginner?
79CJ7dude is offline
post #2 of 16 Old 04-28-2013, 02:58 PM
ezk83
Im in the same boat. And haven't heard anything bad about the harbor freight. So I may be getting it this week unless I hear different here.
ezk83 is offline
post #3 of 16 Old 04-28-2013, 03:00 PM
Soldier905
1988 MJ Comanche
I use the 90amp flux core welder from harbor freight and it works great from what ive done with it so far . I think its a great item to start out on then to work up to the nicer welders out there .
Soldier905 is offline
post #4 of 16 Old 04-28-2013, 03:06 PM
JEEP_Nut1218
I too, have the HF 90 amp. It's a decent welder and will get the job done for the most part.
If you plan to get into welding/fabricating seriously though, I'd say it'd definitely worth saving up a bit and getting an entry level MIG w/ gas.
It will weld much cleaner and nicer than any flux-core.
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
post #5 of 16 Old 04-28-2013, 03:10 PM Thread Starter
79CJ7dude
1979 CJ7
What do you think of the Eastman 135amp mig?
post #6 of 16 Old 04-28-2013, 03:12 PM Thread Starter
79CJ7dude
1979 CJ7
If you go buy an issue of jeep magazine there's a coupon in it for the welder for $89.
post #7 of 16 Old 04-28-2013, 06:05 PM
ezk83
Ya thats another reason im leaning toward that. And harbor freight is only about 20 mins away. Witch does get me in trouble now and again.
ezk83 is offline
post #8 of 16 Old 04-29-2013, 02:03 PM
mchadpayne
With welders you will get what you pay for! The small miller and Lincoln wire feeds word descent on stuff up to 1/8". If you use gas it will make some really nice welds. I have welded with every machine on the market and I finally bought one for my garage and it was the miller stl 150. The reasoning behind this is simply because I can use it for tig and stick and make beautiful strong welds, and I can do this while its plugged into a simple 115 plug. The tig side of it can be intimidating but I'm sure someone close to you would give some direction.
mchadpayne is offline
post #9 of 16 Old 04-30-2013, 08:56 AM Thread Starter
79CJ7dude
1979 CJ7
Well I ended up buying a hf welder last night, hopefully it will be good anuff in till I can buy a lincoln 140.
post #10 of 16 Old 05-01-2013, 08:33 PM
SadDayPanda
I bought a Hobart 140 and I love it
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #11 of 16 Old 05-02-2013, 04:41 PM
jepp
Junior Member??
I just got a Hobart 190, it is a very nice machine and should do everything I would ever want to do. $649.00 at Tractor Supply, $716.00 with tax. I considered the Longevity 200, at about $50.00 less, but on advice from people here and the welding forums I stuck with one of the big three US made welders. Better to cry once than get a lesser machine that you will very likely have to up grade from in the future. My opinion only, good luck with your decision whatever it will be.
jepp is offline
post #12 of 16 Old 05-14-2013, 12:06 PM
SadDayPanda
How does it do with thinner metals? 1/16 , 22 gauge, ect
87, 93, 95 YJ
92, 98 XJ
87 J10
post #13 of 16 Old 07-30-2013, 04:09 PM Thread Starter
79CJ7dude
1979 CJ7
Terrible, it sucks. But I just got a Hobart 190 and man is it sweet!
post #14 of 16 Old 07-30-2013, 05:38 PM
larjeep
Just buy a better wire for the harbor freight welded. Like a Lincoln wire. And it works so much better.
DO IT ALL, AND THAN SOME!
larjeep is offline
post #15 of 16 Old 07-30-2013, 08:24 PM Thread Starter
79CJ7dude
1979 CJ7
I bough some Hobart wire for it , but I never bothered with it cause I thought it was just a waste of time messing with it when it couldn't even weld what I need to weld.
