first timer flux core welder. fist project. - Page 3 - JeepForum.com
post #31 of 38 Old 08-08-2011, 04:14 AM
wushaw
Rockin jeep
wushaw's Avatar
My last welder was a MM175, I really like this machine.
wushaw is offline
post #32 of 38 Old 08-16-2011, 11:05 AM
cotoole
Originally Posted by wushaw View Post
Mig has lots of splatter? Really? As you can see in this pict the burn has not been removed and it is a fresh bead. There has been no spray applied either.
I get this kind of bead pretty regularly with my mig, I do get a buck shot or two every now an again but not often.
are you using gas or just wire? i'm looking at getting a welder soon and can't decide stick or mig. the bottle would have to wait until additional funding could be procured.
99 wrangler sport, 32x11.5 MT/Rs, CB, FIPK, Home-made sliders/rocker guards, Black mountain Hardtop (get a GR8Top), and an UGLY bumper.
cotoole is offline
post #33 of 38 Old 08-16-2011, 08:17 PM
77351wcj5
Looks like there are some excellent welders here, maybe you guys could help figure out why I always have so much buckshot on my welds.
77351wcj5 is offline
post #34 of 38 Old 08-17-2011, 07:36 PM
ramlebliberty
How far are you holding the tip of the gun from the piece your welding? You want to hear bacon cooking while your welding mmmmmm bacon.... back on track, If your using MIG outdoors, maybe you should think about getting something to shield you in while your welding, wind will disrupt the gas flow..
If your using a Stick welder or Flux... yea, its going to be splatter city.. deal with it. The grinder is definitely your friend!
Get some metal and practice, I've been welding for 3 years now, Ive done everything from TIG welding aluminum battery boxes on trucks, to flux core welding exhaust manifolds that were leaking. And I'm still learning every time I get behind the trigger
Check the tips page for miller, good info here.
http://www.millerwelds.com/resources...tips/MIG_tips/
ramlebliberty is offline
post #35 of 38 Old 08-17-2011, 07:42 PM
wushaw
Rockin jeep
wushaw's Avatar
My MM175 had a lot of splatter no matter what I did, I use the same brand & roll of wire on my Hobart 230 and I used the same gas bottle and there was an immediate difference between the two.
My conclusion was not all welders are created equal.
Not saying it's the welder but it could be, especially if you have tried everything under the sun to correct the problem.
wushaw is offline
post #36 of 38 Old 08-18-2011, 10:14 AM
2girlsAndaGuy
1979 CJ5
if you are still using the original wire that came with the HF 90amp then you will keep getting ugly welds till you change it. That wire that comes with it is worthless! Get some new wire and you will notice a huge improvement in splatter and bead quality.
David
2girlsAndaGuy is offline
post #37 of 38 Old 08-18-2011, 11:08 AM
hallway94yj
This is very true, I got a chance to mess around on a neighbors Lincoln 220v mig with basically the same settings as me. 75/25 gas, with hobart .30 wire and the arc quality on my hobart is so much nicer!
hallway94yj is offline
post #38 of 38 Old 09-15-2013, 09:21 PM
Bobbyreb97
thats some good welding! also thin metal do a start stop teqnique. it works for me keeps the heat from building up. also thin its good to lower voltage and up the wire speed
Bobbyreb97 is offline
How to: Make a Trail Mig (Flux Core) welder sherlocktk Fabrication Shop 44 05-26-2015 09:39 AM
Welder wont feed wire (MIG/Flux Core) AlTheKillerr Fabrication Shop 17 01-18-2010 10:10 AM
mig vs flux wire welder 3S00W Fabrication Shop 14 11-27-2009 07:58 AM
flux core welder questions 97tjgunner Fabrication Shop 9 06-20-2009 07:27 PM
which wire is better for flux welding on 3/16 with a 110 welder micahtbyrd Fabrication Shop 4 06-11-2008 07:36 PM
