first timer flux core welder. fist project. - JeepForum.com
post #1 of 38 Old 08-02-2011, 02:54 PM Thread Starter
DoctorTim
i want to make a roof rack with my 90A flux core welder. any tips and tricks i should know about? I've also been practicing on scrap metals and I am having a hard time welding thin sheet metals.
thanks guys
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #2 of 38 Old 08-02-2011, 03:27 PM
Machinist
thin metal will be a little harder with flux core as it burns hotter.I think a roof rack will be a great first project
Machinist is offline
post #3 of 38 Old 08-02-2011, 08:23 PM
bigwahini
My first project for my Handler 140 was a welding cart for it . Got bed frame for $10 and went to town. Came out ok. Some day I plan on a front bumper and trailer.
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #4 of 38 Old 08-03-2011, 05:42 AM
Apollo21
I learned stick at sea came home bought a 140 Hobart on ebay for $350 and taught myself MIG with some help from friends. My first and current project is a rear tire carrier.
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #5 of 38 Old 08-03-2011, 06:59 AM
RedlegWJ
With flux core, take the sheath off the tip, it won't go through tips quite as fast. Get some welding paste to dip the tip in once in a while too, to help them last longer. If you're having trouble laying a bead, try slowing the wire speed down. Prep-grinding is everything too.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #6 of 38 Old 08-03-2011, 07:33 AM
mj40
1989 MJ Comanche
mine works great as long as its-new/fresh clean. steel any rust- it'll sputter
if you need to use an extension cord- use a good one..
keep the ground close to your work/weld..
and grind it clean before welding...
mj40 is offline
post #7 of 38 Old 08-03-2011, 10:41 AM
dcorn
Same here, if the metal is dirty at all, it spatters all over the place. I'll have to try taking the sheath off the tip so I can get in some tighter spots. Or I think my HH140 came with a flux tip.
One of my first welding projects was my exhaust, which was pretty tough since it was thin steel. Burned through a bunch. Just keep the heat setting low. I followed the recommended settings on the inside of the welder, and I'm sure you can find the same stuff online for your welder.
Welding thicker stuff is definitely easier to get the hang of because you can go slowers and really focus on the technique.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #8 of 38 Old 08-03-2011, 02:39 PM
77351wcj5
What they said, plus keep all your gaps tight when you fit everything.
77351wcj5 is offline
post #9 of 38 Old 08-04-2011, 05:50 AM
dodger889
Light weight sheet metal will be harder to learn to weld. To keep from burning through use a heavier piece of metal behind it helps a little.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #10 of 38 Old 08-04-2011, 11:06 AM Thread Starter
DoctorTim
tanks everyone. one last question how to i get perfect 90% angles?
post #11 of 38 Old 08-04-2011, 12:49 PM
77351wcj5
Use a square?
Or, if you are talking about tubing, get a tubing notcher off of ebay. Google "ol' joint jigger" and see what you find...
post #12 of 38 Old 08-05-2011, 02:25 PM
Jamesbbh
For right angles with tube I use a right angle Jig made for carpentry work, it's just two clamps that face each other at a perfect angle.
Build thread (sorta)
Random stuff I've made thread
Jamesbbh is offline
post #13 of 38 Old 08-05-2011, 02:28 PM
Jamesbbh
One of my fist projects- a bracket to hold the CO2/argon tank on a trailer. Here is the right angle Jig
Before you tackle an actual project though you should look into making something like this. This was the second thing other than random scraps I ever welded. It teaches you a lot about angles/joints and just welding in general. Good luck man!
Jamesbbh is offline
post #14 of 38 Old 08-05-2011, 04:24 PM Thread Starter
DoctorTim
first project. what you guys think? i keep getting lots of splatter even if im cleaning the metal beforehand. I've also tried limiting the wire feed but i still get splatter. I also regularly burnt through the thin metal but with the thicker L channel pieces i think i did really good for a first project.
post #15 of 38 Old 08-05-2011, 05:53 PM
craigbru
2007 WK
I've got the same welder, and am well aware of what it can and can't do. I bought it for a few simple projects and it's worked fine, but... I ditched the wire that came with it and bought some nice Hobart flux core. It made a huge difference for me. If you can rule out cheap wire, then it will be easier to practice welding. Otherwise it's hard to tell whether it's inexperience or the wire causing your issues.
Jeep-Core
craigbru is offline
How to: Make a Trail Mig (Flux Core) welder sherlocktk Fabrication Shop 44 05-26-2015 09:39 AM
Welder wont feed wire (MIG/Flux Core) AlTheKillerr Fabrication Shop 17 01-18-2010 10:10 AM
mig vs flux wire welder 3S00W Fabrication Shop 14 11-27-2009 07:58 AM
flux core welder questions 97tjgunner Fabrication Shop 9 06-20-2009 07:27 PM
which wire is better for flux welding on 3/16 with a 110 welder micahtbyrd Fabrication Shop 4 06-11-2008 07:36 PM
