Quantcast Finished my rear bumper. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Finished my rear bumper.
Old 08-15-2009, 02:39 PM   #1
Scotch740
Finished this a week ago or so.
Started with this.
Cut out some holes.
Welded the mounts everywhere I could.
Decided to use Besrks method for the hinge.
Took to it with a lathe at work and got it looking pretty good.
Tight clearance.
Built some frame tie ins from 3/8" angle. I wouldn't do this again I would just buy some. Too much work.
Scotch740 is offline   Reply With Quote
Old 08-15-2009, 02:51 PM   #2
Scotch740
Hi-Lift mount.
Didnt have access to a camera for a bit...
Same type of hold open latch.
Added a 3rd crossmember tie in even though the cross members weak.
Same latch setup Besrk uses.
upper support, put a 1/4" aluminum plate on the tailgate for when I back into stuff.
CB antenna bracket.
3rd brake light.
Old 08-15-2009, 02:54 PM   #3
Scotch740
The lights are wired on a 3 way switch to come on with my reverse lights, or independently or off.
Nothing crazy new, Just a compilation of ideas that I liked. Big thanks to Besrk for doing the R&D
Old 08-16-2009, 12:17 PM   #4
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
Nice looking bumper...
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 08-16-2009, 04:50 PM   #5
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice!! Turned out great! How do you like that single sided "A" Frame setup?
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 08-16-2009, 06:51 PM   #6
Scotch740
Thanks!
I like the single sided A frame because it made mounting the hi lift really easy. Plus it keeps my options open for mounting a jerry can in that spot with less modification in the future. I was slightly concerned about the strength until I welded it up. Its stout as hell and I can shake the entire jeep with it.
Old 08-16-2009, 07:14 PM   #7
Unlimited04
Unlimited04's Avatar
very nice work scotch!!
excellent design, you thought of everything
Unlimited04 is offline   Reply With Quote
Old 09-02-2009, 11:14 AM   #8
ScottHarr_TJ
Wow, just found this thread and it looks awesome man. Out of curiosity, why not add in another triangular support beam on the side with the hi-lift? I like all the cool little mods you added on too.
00' TJ
Blue Jeep Club Memeber #132?
My Custom Back Seat Box Build
ScottHarr_TJ is offline   Reply With Quote
Old 09-02-2009, 01:47 PM   #9
Scotch740
It leaves room for the hi lift mount. Also its less for me to cut out if I decide to mount a gas can back there. Its plenty stout with one. I was going to add some plate connecting the vertical piece and the swing arm but honestly I forgot.
My only issue so far is the paint job sucks big time. Not sure what I did wrong but it will come off too easily in my opinion. I did all my usual prep but used paint thinner to wipe it down instead of acetone which I though would be fine, but maybe not. Also it was a LOT more humid when I painted it vs other paint jobs I have done, so that is another possibility.
Old 09-02-2009, 10:03 PM   #10
JJs99TJ
Looks pretty good. Instead of using a 3rd tie in at the weak x-member,
why not tie in to the frame underneath the frame rails with a couple tabs?
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline   Reply With Quote
Old 09-03-2009, 01:43 PM   #11
Scotch740
I did tie into the frame rails to the stock locations. Could have added a 2nd bolt down there pretty easily but I just bought premade tabs from Besrk.
The x member tie in was kind of an after thought. the receiver tube was already there so it just involved cutting it at the right distance and putting a scrap piece of plate back there.
Old 09-07-2009, 07:13 PM   #12
green89yj
I really like the look of that with the one diagonal support. What size tire was that exactly?
Build
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline   Reply With Quote
Old 09-07-2009, 07:37 PM   #13
Scotch740
35" bighorn. Only 67lbs plus the rim so probalby 80ish total. I designed it so if I flip the tire plate I could fit a 40. Then after finishing it I realizied when I go to 40s I will be 8 lug so just have to make a new plate anyways. Oh well
Old 09-08-2009, 12:50 PM   #14
Wrangler_91
You happen to have any pictures of your frame tie in setup with it mounted and all. I am going to be building some for my bumper here this weekend or next.
Wrangler_91 is offline   Reply With Quote
Glock Forum
