Finally a new welder! - JeepForum.com
post #1 of 11 Old 06-02-2013, 05:19 PM Thread Starter
TimV
Finally got the chance to pick up a new machine. I had been using an old Snap-On 140amp unit. It proved to be inconsistent at best. Some days it made beautiful welds, other days I wanted to run it over.
Yesterday I picked up a Hobart 210mvp. Also came with a cart and a decent sized gas bottle. Plus a new 10lb spool.
So far I've just done a few test beads on some scrap, but I can already tell I'm going to like this one a lot more. My weld started to pool much quicker, and looks a bit cleaner. I don't have a 230v outlet in the garage yet, but I will definitely be putting one in soon.
My favorite part is that I was probably going to pull the trigger on a brand new one soon. I got this one for less than the price of new, including the bottle.
It's not an addiction. It's a way of life.
TimV is online now
post #2 of 11 Old 06-08-2013, 08:23 AM Thread Starter
TimV
I finally hooked up a 220v outlet in the garage. So I got to play around with that for a while yesterday.
I am having a little trouble with getting my bead to feel consistent. It feels like the wire speed is too fast, but if I turn it down any, it's not fast enough. I am still getting decent welds, and great penetration. I am assuming there is a slight learning curve moving up to 220v?
TimV is online now
post #3 of 11 Old 06-08-2013, 12:32 PM
WSS
WSS's Avatar
1972 CJ5
Sounds like it was a used machine? Make sure your liner is in good shape and not worn out or kinked or even a bugs nest causing the inconsistent welds if it has been sitting a while. 220v should prove to be much smoother than 110. look at your feed rolls to make sure they are clean and not rusty or have some dirt hi spot causing a hi/lo pressure as it turns. Push the wire up against a piece of wood to check roller tension, it should push your hand a little then spin but not crush or bind on the wire (I have a feeder that will accordion .045 and less if I use all four rolls). Post some pics of the welds if you can. What gas/wire type and size combo are you using?
For most "Jeep" work, 70s6 wire (.23-.030) and a good 75/25 gas will work great, a tri mix (ar/co2/o2) mix will produce a more fluid weld in the right situation using 70s6.
Hope that helps!
WSS
WSS is offline
post #4 of 11 Old 06-08-2013, 01:30 PM Thread Starter
TimV
Yes, it is a used machine. I did some more work with it today, and I got better. I actually turned the wire speed up a little and I did better. The welds actually look pretty good. Plenty of penetration. Welding up 1/4" brackets, and it is nice and blue on the back side of the steel. I think part of the problem is I am not used to how much it burns into the material. I'll get a picture up in a bit.
TimV is online now
post #5 of 11 Old 06-08-2013, 01:45 PM Thread Starter
TimV
Here's a couple pictures of what I did today. Running .035 wire, with C25. Actually, the wire might be why it seems different. I had .030 in the other welder. I was also using 75/25 Argon/co2 before as well.
Sent from AutoGuide.com Free App
TimV is online now
post #6 of 11 Old 06-08-2013, 01:59 PM
Ironworker709
Ironworker709's Avatar
not too bad....get out of the habit of whipping the puddle and run one consistant hot pass...you have alot of undercut..start doing just a steady consistant pass and watch the fill...let it fill just to where you see the puddle completely fill...
Whipping back n forth and in and out causes undercut and weld stress
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #7 of 11 Old 06-08-2013, 02:13 PM
WSS
WSS's Avatar
1972 CJ5
X2, w/110 you probably did not have a choice, now the weld is you oyster, did I just say oyster? LOL Your on! Have fun.
WSS is offline
post #8 of 11 Old 06-08-2013, 02:14 PM Thread Starter
TimV
Didn't know that. Thanks for the tip. I'll definitely give it a try next time. So just kinda run straight down the joint? Or move back and forth very slightly?
TimV is online now
post #9 of 11 Old 06-08-2013, 02:23 PM
WSS
WSS's Avatar
1972 CJ5
Let it flow first, then oscillate a little if it does not reach what you intended. Keep in mind a double pass may work better if it is too wide. Your oscillation should be faster than your pics show. Practice a lot.
WSS is offline
post #10 of 11 Old 06-09-2013, 02:55 PM Thread Starter
TimV
Trying it more like you guys said. How's this look?
TimV is online now
post #11 of 11 Old 06-09-2013, 03:58 PM Thread Starter
TimV
These definitely look a lot better than I was doing yesterday. At least in my opinion. Here's one more:
TimV is online now
