Finally finished the Removable Steps - JeepForum.com
post #1 of 6 Old 10-31-2003, 03:59 PM Thread Starter
MangesMade
I started this project mainly because the steps were to high for Gr. Ma to get up on when they were bolted directly to the underside of the floor. Besides that, when you stepped up on them, they were so high that you had to duck to get in. They were just cumbersome to get on and off of
So I made a set of female receivers to bolt onto the frame.
Then with a MangesMade Bracket, I welded it to a short piece of square tubing, Then I bolted the factory steps to the Bracket.
The Square Tubing mates to the receiver on the frame and is
held in place by a pin.....Just like a trailer hitch.
IF the going should get rough or if I need to transfer them to my other Jeep, (which will also have a set of female receivers bolted to its frame). I can easily remove them by just pulling the pin and the complete assembly slides out.
Thanks in advance for any ideas to better them.....
Whew !!!!! It took longer to post these pictures than it did to build it all.
Getting Started:
Placing a thin piece of Card Board between the reciever and
Square Tubing to maintain a good fit:
One Done :
Showing how it fits together:
Pin is visiable between muffler and step.
Sorry about the Dirt
Finally Gr. Ma can get in easily
"Keep 'em Razor Sharp"
Mike
MangesMade is offline
post #2 of 6 Old 10-31-2003, 05:05 PM
CETROV
CETROV's Avatar
That is pretty sweet. Nice job!
97 TJ
CETROV is offline
post #3 of 6 Old 11-01-2003, 09:48 AM
rustyCJ
so how far down does your step receiver hang past the bottom of your skid?
will getting hung up on them be a concern?
like the fab skillz and idea
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #4 of 6 Old 11-01-2003, 04:42 PM
V8Racing
Wow nice job mate, i might to do that on my cj
V8Racing is offline
post #5 of 6 Old 11-08-2003, 11:09 PM Thread Starter
MangesMade
RustyCJ
You asked "so how far down does your step receiver hang past the bottom of your skid? will getting hung up on them be a concern?
I'm sorry it took so long to reply.....
Yes the reciever hanging down would be a problem if I were to be dragging on my frame.....but it wouldn't be as bad as dragging the whole step.
The step receiver hangs down just a few inches below the bottom of the frame rail. BUT, the Tansfercase Skid hangs down further.
BTW.....the only reason that it hangs down is because I had to come under the muffler. The headers are outside the frame type headers and the muffler is between the frame and outside edge with the exhaust pipe coming out right in front of the rear tire.
I had to work around that. I couldn't go over it as it's to close to the floor. Had that not been in the way, I would have mounted the step reciever higher on the frame and just angled the (Male) square tubing and step to a decent step height....Then when removed, nothing would have been hanging down.
If you don't have anything in the way, you could bolt it level with the frame rail or higher..... If you are able to step up to the higher step, you could bolt it to the frame rail leaving just enough room so that the ( male ) square tubing doesn't touch the bottom of the floor to vibrate.
Thanks, Hope this helps.
Mike
post #6 of 6 Old 11-08-2003, 11:17 PM Thread Starter
MangesMade
V8Racing.....
Checked out your site.....
Wish I had the time to do what your doing......Have you started putting it back together yet ?
Mike
Finished the cage finally scrapinrocks Fabrication Shop 5 03-10-2009 12:42 PM
Finally finished lift alexrule123 Street Jeep Forum 24 08-05-2007 11:10 AM
Paint Job finally finished jasonamorris General Jeep & Off-Road Equipment 14 11-28-2006 01:05 AM
Finally finished my paint eclipse27 General Jeep & Off-Road Equipment 3 07-21-2006 12:22 AM
Finally finished my bumper dzp Fabrication Shop 32 04-21-2004 08:32 AM
