Face Mounting a Stinger.. - JeepForum.com
post #1 of 5 Old 09-22-2012, 03:42 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen a few folks ask about how to cut/mount a stinger to the face of their bumper. Since I was working on one this morning, I thought I'd snap a few cell phone pics and explain how I work out the cuts on the ends of the legs..
After bending the stinger, I use a Roofing Square and put a "reference mark" on each leg.. at the end of the square.
I can then measure an equal distance from those reference points to cut the legs to length.. with both sides symmetrical..
Next, I stand the stinger up on a flat surface (here a piece of steel sheet) and prop the tip of the stinger up with something (like a jackstand)... I use an angle finder to get the desired angle (usually somewhere around 45-50deg or so..)..
Once I get the stinger at the desired angle, I mark the bottom of the legs with a paint pen. I lay the pen on a spacer (here a piece of 1" thick scap), and slide the pen around the end of each leg. It's important that the pen lay flat on the spacer.. and remain horizontal as you slide it around.. don't let it tip up/down at the end.
I then clamp the stinger in a vise and orient the cut lines so that they are "vertical" when seen from the end. This makes it easy to simply cut straight down the line..
Last step is to cut the ends with whatever tool you have.. Portable Bandsaw, Sawzall, Plasma, Cutoff Wheel, even a Hacksaw..
If you use this method, it's fairly quick and usually results in very little grinding to get the legs nice and flat against the bumper surface. With the bandsaw, it probably took me about 10mins to do all the marking/cutting.
BESRK is offline
post #2 of 5 Old 10-01-2012, 01:50 PM
ltrail
1984 XJ Cherokee
Well done sir! Where's the mounted pic? I believe some bracing and gusset work are in order.
Kepp it up.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 5 Old 10-01-2012, 09:48 PM
tdkask
Nice basic technique tutorial. These things seem so simple and basic after you know them, but are the things you pick up early on that help out a new hobby fabricator. Keep 'em coming.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #4 of 5 Old 10-02-2012, 04:27 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Kepp it up.
Didn't take any finished pics... I just finished up the bumper and shipped it. I do quite a few of these. I've tried to answer the question on how to do the stinger, but had never bothered to take pics. Since I wasn't too pressed for time, I thought I'd shoot some pics on this one..
BESRK is offline
post #5 of 5 Old 10-02-2012, 06:01 PM
webdog
DirtBound Offroad
1990 XJ Cherokee
I just did a bumper today and normally use the bandsaw method, but today I tried the chop saw with allows for compound cuts and it worked great.
webdog is offline
stinger Mounting underpowered Fabrication Shop 7 10-20-2010 02:58 PM
Help mounting some AJ's rails (old mounting setup- no pinch seam) HenryKrinkle Fabrication Shop 2 06-30-2010 03:27 PM
stinger mounting problem frumpy Fabrication Shop 19 10-23-2008 07:47 PM
How can I get a face? samger2 Audio, CB & Ham Radios, GPS, & Electrical 6 02-26-2007 11:03 AM
which way to face? mytjnamedrex Audio, CB & Ham Radios, GPS, & Electrical 3 10-01-2001 02:41 PM
