Fab Shop Humor - JeepForum.com
post #1 of 10 Old 11-29-2010, 05:53 PM Thread Starter
GilpinTJ
GilpinTJ's Avatar
Fab Shop Humor
Oldie but a goodie:
TOOLS EXPLAINED: How True This Is.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, "Oh, sh*t!"
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use..
SON OF A B*TCH TOOL: Any handy tool that you grab and throw across the garage while yelling "Son of a b*tch" at the top of your lungs. It is also, most often, the next tool that you will need.
John P.
Colorado Jeep Club Member #494
GilpinTJ is offline
post #2 of 10 Old 11-29-2010, 06:30 PM
Area.3.Fiftyone
Good stuff although I don't see any mention of the ole' "fire wrench".
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 10 Old 11-29-2010, 08:24 PM
Jason
I think my Son-of-a tool is broken. Usually it flies across the garage with a more colorful and vulgar exclamation. Perhaps I can get a refund?
Funny stuff. I've not yet seen this list.
Jason is offline
post #4 of 10 Old 11-29-2010, 08:31 PM
trxridr
im guilty of the son of a tool too, had to go get a new craftsman ratchet cause of it, it was worn anyways but they wanted to know how it got road rash on it (landed on the driveway)
1999 wrangler, 4.0l five speed, 4 inch procomp lift, 1,25 body lift, 1 inch mml, d30 front, ford 8.8 rear with 4.10's, 35 inch km2's
"When in doubt, Hammer out"
trxridr is offline
post #5 of 10 Old 11-29-2010, 08:44 PM
rugsucka
Angle Grinder - A high speed self cauterizing wound maker capable of wrapping sleeves, wrecking gloves and throwing small pieces of whatever you are working on into your eyes.
rugsucka is offline
post #6 of 10 Old 11-29-2010, 09:57 PM
JA66
Safety Glasses - False hope for your eyes.
JA66 is offline
post #7 of 10 Old 11-29-2010, 10:09 PM
Jason
... used to carry moisture near your face should your eyes need more than normal. Especially effective with protective breathing mask.
Jason is offline
post #8 of 10 Old 11-30-2010, 09:19 AM
Area.3.Fiftyone
That is so true right there.
post #9 of 10 Old 11-30-2010, 09:26 AM
jeepinvader
So true!
Free Chuck!
jeepinvader is offline
post #10 of 10 Old 11-30-2010, 10:13 AM
wozz
good stuff
wozz is offline
need 4x4 shop in NC creepyjeep420 Fabrication Shop 1 09-01-2010 10:58 PM
Looking for 4x4 shop in Nor Cal Libtekguy General Jeep & Off-Road Equipment 3 03-06-2009 10:29 AM
What do you have in your shop? Absolutexero Fabrication Shop 7 01-26-2009 11:58 PM
How do I find a local CB shop - or "good shop in ATL?" Magnum Audio, CB & Ham Radios, GPS, & Electrical 14 03-23-2007 10:27 AM
Mod Shop? Fropleyqk Tires & Wheels 3 02-07-2005 08:26 AM
