Fab shackles - JeepForum.com
post #1 of 5 Old 10-28-2013, 02:22 PM Thread Starter
TXHUNTER247
Fab shackles
Have some very heavy duty flatbar and need to get an additional 2" lift. You think making some new shackles will work out for me? Keep in mind this is just a drive around the ranch cj5 and won't be doing any rock crawling or heavy mudding
TXHUNTER247 is offline
post #2 of 5 Old 10-28-2013, 05:25 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
While longer shackles can be used for some minor lift, you'll have to make them 4" longer than stock in order to gain 2" of lift. So on a CJ.. you're looking at shackles that will be 7" eye to eye. That kind of length will rotate all the positive caster out of the front axle. If it's just a farm beater, that probably won't be a big issue, but it might be kind of squirrely going down the road at speeds above about 30-35mph.
But yeah.. shackles are nothing more than flat plates. So, some flat plate around 1/4"-3/8" thick should work fine.
BESRK is offline
post #3 of 5 Old 10-28-2013, 05:40 PM
andrewmacc
Since they'd be so long, if you run them out of 1/4" plate, I'd probably add a little gusset in the middle. Highly unlikely something bad would happen, but the longer they are, the more susceptible to getting bent out of shape they are..
edit: like you said, farm beater, but really long shackles will actually increase sway etc.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #4 of 5 Old 10-30-2013, 08:30 AM
Renegade82
1982 CJ7
If they're going to be that long use 3/8" or they will eventually bend. A full length block between will help and keep them parallel. But the bigger concern, once they're on, will be the added torque to the stock frame mounts. These can twist and / or crack with the added leverage.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #5 of 5 Old 11-01-2013, 10:53 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I did a little frame repair and new shackles on this CJ5. 3/8" shackles 6" long for 1.5" lift. I drove it up to put a little gas and give it a bath for the customer and it drove great (other than the sloppy oem steering box). The 3/8" shackles required a bit of grinding (1/4" clearancing) on the front crossmember to fit them. Don't forget to account for new bushings at the leaf end and shackle frame end. I highly suggest poly bushings. Rubber ones squish out easier with the the increased shackle length on flex.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
