F350 to Jeep steering problems - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > F350 to Jeep steering problems
Metalcloak: Celebrate Freedom with Free ShippingFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-17-2015, 05:47 PM   #1
darren2569
Im trying to figure the steering setup to swap a D60 from a 2010 F350 into a 04 TJ. The plan was to use 1.5"ID DOM and weld in the correct inserts to use the factory ford TRE at the axle end and the stock Jeep TRE at the pitman arm. However I cant find a 22x1.5mm threaded insert anywhere. Does anyone know of where I can get one or how to get around it?
TIA
darren2569 is offline   Reply With Quote Quick reply to this message
Unread 06-26-2015, 01:03 AM   #2
levergun
1979 CJ5
Use GM 3/4 TRE. they are 7 degree taper with 7/8 threads. bungs are easy to find and I believe ford uses the same 7 degree taper.
Then simply buy a reamer and ream your pitman to the matching taper. That's what I did when I went tons.
Also I wouldn't even think of using a stock Jeep TRE with this swap. They are way to small.
I think the part number for the TRE's are ES2010L ES2010R. Or if you need the longer shanked ones It's ES2027 or ES2034 IIRC.
1979 CJ5 408 AMC
1988 YJ 331 Stroker
levergun is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 12:42 PM   #3
partegolkar
Good suggest, I will try it
partegolkar is offline   Reply With Quote Quick reply to this message
Unread 07-03-2015, 12:39 PM   #4
tkfx
This is what I would have done.
http://www.pirate4x4.com/forum/axles...teer-kits.html
My Build Thread:
http://www.jeepforum.com/forum/f22/tks-yellow-krait-ljk-buildup-2337401
tkfx is online now   Reply With Quote Quick reply to this message
