"Evo Style" Tire Carrier - JeepForum.com
post #1 of 9 Old 04-22-2014, 02:55 PM Thread Starter
mike1087
This is only my 2nd build and Im still new to welding so its not beautiful but it seems solid!
Ive been wanting a tire carrier to get my 35 out of the back so I can get my seat back in there. I really liked the body mounted carrier that evo offroad makes for the JK's so I thought I would try and replicate that.
I do not have a tube bender and after a month of trying to figure out if I could afford that plus all the tube I came up with another idea. I previously used AtoZ rock sliders to make them myself and realized the bends were perfect for what I was looking for.
Took some measurements, called them up and had them pre-bend me tube and I had them leave extra on the ends so I could trim them down myself. I also had them do the stinger hoop on the rear. The quality and price were great for them both.
I used heim joints with a 5/8 in bore for the ends. Since I am very new to fabricating I wanted the ability to adjust the ends to length in case my cuts were not perfect or my hinges were not welded in the exact spot they needed to be.
End of day, Im very happy with the outcome and just hoping it doesnt rip off the back while driving down the road!
Hope you like!
Before I trimmed the ends:
Before Paint:
Installed:
02 TJ 4.0 | D44 Rear | 4.88 Yukon | OX Rear Locker | 35x12.5x15 MTR-Kevlar | 15x8 Ultra 061
mike1087 is offline
post #2 of 9 Old 04-22-2014, 03:54 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Nice! Good call on using pieces of bent tubing too.
BESRK is offline
post #3 of 9 Old 04-22-2014, 06:54 PM
JEK3
JEK3's Avatar
Looks like your vertical supports are blocking the tail lights, but it could just be the picture angle. How does it look to a car behind you?
JEK3 is online now
post #4 of 9 Old 04-22-2014, 07:01 PM Thread Starter
mike1087
Yea they are slightly. Trying to decide if I should cut some holes in the supports or not.
Any ideas?
mike1087 is offline
post #5 of 9 Old 04-23-2014, 12:15 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I would actually wire in some additional LED lights off of your trailer wiring connector, so that you don't have to worry about visibility and it would look pretty cool. Especially since you don't seem to have any rear side marker lights which will bite you in the butt, especially in MD,VA and DC. I know, I lived in NoVA. I would also look at fabbing some fenders to match because your carrier looks great.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #6 of 9 Old 04-23-2014, 01:18 PM
MarkNog
I like how it keeps the tire lower than normal. Can we get some more pictures from a little further away?
I was debating on making one like yours or like TNT customs carrier.
http://www.tntcustoms.com/Jeep_TJ_LJ...e_carrier.aspx
MarkNog is offline
post #7 of 9 Old 04-23-2014, 04:57 PM
lar308
Very nice work, I will be using some design points from your carrier, again nice work. Ron
"Snowball" 1990 YJ, 4.2, Weber, HEI, 3.5" springs, .5" boom shackles, dana 44's, 5.13's, Detroit locker's, 4340 axle shafts, 1 ton trod ends, Tom Woods SYE & rear shaft, 35" MTR's on V5 cragars, M8274
lar308 is offline
post #8 of 9 Old 04-24-2014, 03:19 PM Thread Starter
mike1087
thanks for all the comments guys. Im going to add some additional lights as mentioned about, just need to figure out where I want to put them.
Ill post some more pics soon from further away.
mike1087 is offline
post #9 of 9 Old 04-24-2014, 05:43 PM
lar308
I was thinking of possibly using the oval tractor trailer lights in the rectangle tubing uprights, Just a thought. Ron
lar308 is offline
