#1 | |
sorry repost
I'm looking to get into welding and I"m looking for an entry level Arc welder....Lowe's has one for 250 or so but it's 220v, and I don't have 220 where I live really.....Are there any relativly cheap 110V arc welders out there?? Thanks
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top Last edited by Pipedrummer; 01-26-2007 at 02:32 PM.. Reason: sorry repost |
#2 |
By Arc you are talking stick?
[SIZE="1"][B]98 TJ-bought-not built [url]www.PNWJeep.com[/url] كافر - Infidel[/B][/SIZE] |
#3 |
arc welding is stick welding
#4 | |
#5 | |
~~~~~~~~~~~~~ Pipedrummer, Do you have an electric dryer at your house? If so, you have 220 single phase. Look in your electric panel and see if you have any double pole breakers. 220 single phase has two live wires and a ground compared to 110 which is one live wire, a neutral and a ground. |
#6 | |
#7 |
I'd recommend a Lincoln Pro-Mig 135 around $350-400, you can run it on 110v.
For the non-welders and wannabe's, MIG stands for Metal Inert Gas which is a subtype of GMAW which stands for Gas Metal Arc Welding. In fact, TIG welding is also arc welding... Basically, arc welding, does not mean stick.
"Aut viam inveniam aut faciam" - I will either find a way or I will make one. 1995 YJ, SOA, D44/60, 35"s 2008 Dodge Ram SLT 4x4 www.secretreality.com |
#8 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#9 | |
ditto in the welding world, stick is arc, tig is tig, and mig is mig... the fact that the op is buying an "arc" welder for 250 at lowes shoulda clued you in but to answer the origional question, in my experiance 110 is crap, unless you want the extent of your welding to be tacking sheet metal... ive got one of those little amp boxes to use when i only have 110, and it always shorts on me when i use it, im no electrician... to do any usefull welding you really need 220 |
#10 |
I agree, but ive heard it used to decifer between torch welding and "arc" whether it be MIG, TIG or stick.
#11 |
my dad just picked one up the other week from home depot for about 350 or so. a lincoln flux welder that can be upgraded to a mig welder. 120 volt input and can handle up to 1/4 steel. i used it this last weekend and it seems to work good for a 120 volt unit. good enough for the average joe for home with a budget. or look for a used one, but be very careful that way, and make sure to check it out first.
Your lack of planning does not constitute an emergency on my part 1992 XJ Laredo 4.0L, AW4, NP242, 3.5" RE super ride Definity Dakota 31x10.50 MT's Cragar soft 8 Marine Corps Jeep club member #9 |
#12 |
German car snob
lincoln is so far ahead of anyone in the welding game. I am getting a 140E when pay permits.
- Brian Klein Concept and Design KCD Website Follow us on Facebook! XJ Writeups: | DOORLESS IN A 97+ | D44 SWAP | REBUILDING A CV DRIVESHAFT | HOME-BREWED CENTER CONSOLE |
#13 | |
WTF is that?
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#14 | |
#15 |
Sure, but i wasnt going to go that indepth in defendence of any type of eletrical welding being refered to as "ARC". Heli Arc welding is when helium is used as a sheilding gas, and though argon is commonly used since its cheaper, TIG is still reffered to as Heli Arc by the old schoolers.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
