Dune buggy tire carrier! - JeepForum.com
post #1 of 13 Old 03-24-2013, 12:28 PM Thread Starter
CrazyJeepMan92
Alright so I started building my dune buggy tire carrier off of the bumper I made.. What do you guys think so far?
I'm using 1.5 in .120 wall steel tubing. Cut the stock tire carrier up to make the tire mount, and used the sway bar links as the joint off the bumper. I will update as I get more done.
NATEF/ASE Certified
US Marine MOS: Diesel Mechanic
Fabricator/Mechanic Kool Kidz ATV
CrazyJeepMan92 is offline
post #2 of 13 Old 03-24-2013, 01:55 PM Thread Starter
CrazyJeepMan92
NATEF/ASE Certified
post #3 of 13 Old 03-24-2013, 04:22 PM Thread Starter
CrazyJeepMan92
I'm calling it a day, just gotta gusset and paint and she's done!
NATEF/ASE Certified
post #4 of 13 Old 03-24-2013, 05:12 PM
Machinist
Is that galvanized?If it be careful,it gives bad fumes when welded.Otherwise I like the concept!
Machinist is offline
post #5 of 13 Old 03-24-2013, 05:25 PM Thread Starter
CrazyJeepMan92
Thank you! And yes it is thanks for telling me good thing I've been welding outside with it
NATEF/ASE Certified
post #6 of 13 Old 03-25-2013, 10:02 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I, do mostly in part to my driving "style" would back into every tree within a 3 mile radius while on the trail with that.
Not being DOM material, that may have a little higher likelihood of getting dinged, but should be ok for on road travels. I would highly recommend you reinforce whatever connection your going to make with the tub. The thin 1/8" thick corners you have on there won't be enough. You'll want to drill through the tub and put backing plates on whatever attachment you decide to use. That design with the tire laying more flat increases the pressure on those mounts significantly. Just don't want you running down the road losing that expensive spare and sparks flying. Even though it would make a great insurance commercial....not so good in real life...
Cheers to you for taking initiative to start building your own stuff....I commend you sir.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #7 of 13 Old 03-25-2013, 10:19 AM Thread Starter
CrazyJeepMan92
I decided last night that I'm adding another tube and a lot of gusset.. I'll update as I go. When it's done it'll be bulletproof
NATEF/ASE Certified
post #8 of 13 Old 03-25-2013, 10:18 PM
JohndKc
1987 YJ Wrangler
More importantly killing the people driving behind you.
33rd BCT
Alpha 2/122 FA
68W
JohndKc is offline
post #9 of 13 Old 03-26-2013, 03:02 PM Thread Starter
CrazyJeepMan92
You haven't even seen how I'm mounting it yet.... Don't you worry about it.. Tomb raider made some good points which I already got covered
NATEF/ASE Certified
post #10 of 13 Old 04-15-2013, 10:25 PM
Tomb Raider
Addicted...
I'm interested in how this turned out....
post #11 of 13 Old 07-01-2013, 09:45 PM Thread Starter
CrazyJeepMan92
Sorry I've been off the forum guys, was busy finishing my ASE certifications. Since I talked to you all last I did my transmission in my jeep. Will update this thread soon!
NATEF/ASE Certified
post #12 of 13 Old 01-25-2014, 10:49 PM Thread Starter
CrazyJeepMan92
Update: Finally got it mounted, going to gusset, put a little plate on and paint tomorrow.
NATEF/ASE Certified
post #13 of 13 Old 01-26-2014, 03:00 PM Thread Starter
CrazyJeepMan92
Update:
Today it rose above 20 degrees so I went out to the shop and worked on a quick disconnect setup. I mimicked polaris and how they connect their roll cages on their SXS.
NATEF/ASE Certified
