Drilling oil - JeepForum.com
post #1 of 18 Old 07-12-2013, 03:58 PM Thread Starter
outbackmatt
Drilling oil
For drilling anything over 3/16" thick I like to use oil to cool the drill bits. I had been using a cutting oil for years without any problem, but my new powder coater is complaining about it causing bubbles in the finish. They suggested using motor oil or hydraulic fluid instead.
What do my fellow fabricators here find effective? I am trying sae 30 oil but any residuals of it burning off from the weld seems to be irritating my throat. I wipe off any excess oil, but still it gets smokey.
outbackmatt is offline
post #2 of 18 Old 07-12-2013, 05:28 PM
sbcranger
I always use 30 wt or ATF when drilling anything .125 or heavier and never had any issues with it smoking when welding...maybe you aren't cleaning it enough?
sbcranger is offline
post #3 of 18 Old 07-12-2013, 05:55 PM
AGDubyaJ
I use rapid-tap for everything at work, never had any problems with it affecting powder coat.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #4 of 18 Old 07-12-2013, 07:47 PM
athos76
Personally, I use coconut oil or Boe-lube. At my shop, we use lard or soluble oil.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #5 of 18 Old 07-12-2013, 08:10 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
we use Tap Magic, and so long as we clean the area afterward with solvent as we do all parts before paint/powder we have never had an issue.
but everything gets cleaned with tri-free brake cleaner before welding or painting.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #6 of 18 Old 07-13-2013, 01:36 PM
youngjeepr
At my work we use boelube we use it on drill bits, power taps, end mills, and even cutting tools on the large manual lathe
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #7 of 18 Old 07-13-2013, 03:40 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've been using a Semi-Synthetic Lube from Northern. I think it's called Mystic or Mistic. It's kind of pricey at $65 per gallon but it goes a long way. One gallon usually lasts me 6-8 months (drilling/milling/cutting/lathe). You mix it 1:10 with water. Good stuff.
BESRK is offline
post #8 of 18 Old 07-13-2013, 04:40 PM
AtTheHelm
Maybe i should try one of these products you guys are using.
I've been using 75w-140 syn gear oil only because it was the first thing I found with a small spout on it, and I've been using the same quart bottle for a long time. I hate the smell and how much it smokes.
AtTheHelm is offline
post #9 of 18 Old 07-14-2013, 05:42 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The stuff that mixes with water can be sprayed out of a squirt bottle. Pretty much odorless.
BESRK is offline
post #10 of 18 Old 07-14-2013, 08:25 AM
underpowered
we use something similar called Kool Mist on all of our mills and lathes at work. on the mills we have misters that spray for us, but on the lathe we use a squirt bottle of the stuff.
odorless and smokeless. it is more of a cooling agent than a lube, but works well.
post #11 of 18 Old 07-14-2013, 01:15 PM
wushaw
Rockin jeep
wushaw's Avatar
Boelube here most of the time.
wushaw is offline
post #12 of 18 Old 07-14-2013, 07:46 PM
holliewood61
holliewood61's Avatar
1981 CJ7
as far as drilling goes ive been using pag oil that you would put in a/c systems. I always seem to have it in excess laying around the shop from where some a/c kits come with a bottle and only require 2 oz or so.
holliewood61 is offline
post #13 of 18 Old 07-14-2013, 08:11 PM
athos76
The stuff you mix with water is soluble oil. Add a few ounces to a soda/water bottle, poke a hole in the lid and mix with water... good to go.
athos76 is offline
post #14 of 18 Old 07-15-2013, 05:45 AM
jason280
I've been using whatever left over ATF or engine oil I have in the shop, and its worked well for me so far drilling up to 3/8" plate. Most of the bits I am using are under 3/4', and I haven't run into any problems. I'm sure some of the other oils mentioned may be better, but I've yet to find a reason to spend money on cutting fluids for my needs.
jason280 is offline
post #15 of 18 Old 07-15-2013, 11:53 AM
firefighter315
Tap Magic x 2....just started using it a while back after it was recommended by a friend that does a fair bit of milling/lathe work. Doesn't smoke real quick and easy clean up. I use it from a squirt bottle made for light oils. I buy it locally at Fastenal. They are cheaper than my other outlets believe it or not.
My YJ Build Thread
firefighter315 is offline
