DOM weldable surface area question - JeepForum.com
post #1 of 7 Old 11-15-2013, 08:07 AM Thread Starter
TXST8tj
TXST8tj's Avatar
Making control arms.
1.5" OD tube
1.5" joint housing width
Is there enough surface area to weld the two pieces together? Considering the joint housing staying the same 1.5", should the tubing be dropped down to 1" OD, or is the 1.5" on 1.5" ok?
A CAD illustration:
Patrick
TXST8tj is offline
post #2 of 7 Old 11-15-2013, 08:37 AM
Danno6102
Grind a bevel around the side of the arm tube to give you a pocket for the weld.
What joints are you using in those? That's a small ID. (if drawn to scale)
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline
post #3 of 7 Old 11-15-2013, 08:49 AM Thread Starter
TXST8tj
TXST8tj's Avatar
Haha. Definitely not drawn to scale. It's what I'm good for in MS Paint.
Using Metal Cloak Joints.
Patrick
TXST8tj is offline
post #4 of 7 Old 11-15-2013, 08:53 AM
Danno6102
thought the narrowest one was 2".
they have a snap ring groove around them, id' be careful about burning into this groove. The snap ring won't fully seat.
post #5 of 7 Old 11-15-2013, 09:05 AM Thread Starter
TXST8tj
TXST8tj's Avatar
These are the 2.25" diameter, 2" joints. The joint housing width is 1.5". The joint itself is 2".
Patrick
TXST8tj is offline
post #6 of 7 Old 11-15-2013, 09:13 AM
Danno6102
Brain fart. 2" mounting width. Durrrr.
I assume with 2" joints these are for uppers. You'd be fine with smaller tube. Currie uses 1"x.156" wall DOM on all their arms, upper & lower. But if it were me, I'd still use the 1.5" on the lowers, they're wider & shouldn't have a problem.
post #7 of 7 Old 11-15-2013, 09:22 AM Thread Starter
TXST8tj
TXST8tj's Avatar
Yes, these are for the rear uppers. I bought the joints a while ago when I was looking for projects to do. Ironically, I never got around to it, but it's time to do something with the parts. I will probably just buy them made from MC next time, but it seemed like a good project.
Patrick
TXST8tj is offline
