Quantcast Do It Yourself Overhead Console - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Do It Yourself Overhead Console
Old 04-26-2006, 06:20 PM   #16
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Originally Posted by VnutZ
I changed another element since I did the write-up. The power wires running up the windshield panel now terminate at the rollbar with some $2 connectors from Radio Shack. These parts include: Male Connector and Female Connector. Now, when the top is off and risk is high, I can leave the equipment at home by disconnecting the power lead and unscrewing the hose clamps. Complete removal and installation time is down to about three minutes tops. True, that means I can't bring my "road-rage-stress-relieving-PA-system" with me ... but unfortunately, my top is on most of the time.
I am still looking into attaching a rabid, poop throwing monkey to a leash into my backseat to protect all my stuff. I just can't seem to train him to not attack me. And the poop gets messy.
You need a trunk monkey!
http://video.google.com/videosearch?q=trunk+monkey
I need a 35" tire for spare. PM me if you have something.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Old 04-26-2006, 09:53 PM   #17
Saltine
I wish my Jeep came with one
Originally Posted by atxzj View Post
The irok is pretty much the thornbirds handicapped cousin.
Rocky Mountain Edition Club, Member #6
Saltine is offline   Reply With Quote
Old 04-26-2006, 10:44 PM   #18
Baotchi
2010 JK Wrangler
One day I'll do something like that... It'll have to blend a little better tho, and be designed in a way that rain can not get to my equipments.
Your design is nice! Things I don't like are your power connection in the fuse box (before you installed the "add-a-line thingy) and the hose clamps.
Simon
Baotchi is offline   Reply With Quote
Old 04-26-2006, 10:53 PM   #19
TJgreg
awesome write up! I'll be getting a cb in the coming months and will probably do something very similar to your project. expect some pm's!
Semper Fi
TJgreg is offline   Reply With Quote
Old 04-26-2006, 11:13 PM   #20
lutzke21
Can you still fuse the circuit that you put that "mini add-a-line" in? I'd still like to fuse whatever circuit is there... (did I explain that right?)
-Scott
Donor Engine OUT!
Colorado Jeep Club Member #24
MINE
33x13.5 Swampers, 15x10 Procomps, ORT bumpers, PIAA 520 off-road lamps, MM 8000 lb winch, Winch solenoid underhood installation, Taurus Fan, Banks Header, Magnaflow Cat, Banks Cat-Back System, IPF Headlight Conversion w/ H4 bulbs, 2" BL, Smittybilt side bars, RE 4.5 XD, RE SYE, Optima red top, Power steering (was manual), 136amp Alternator, Realistic CB, Sony Xplod stereo, 5 ¼” Sony speakers, Infinity Subwoofer, Grant wheel, Mastercraft seats (front/rear), Herc'd floors, Raingler nets, 20 gallon tank, LiteDOTs Taillights, Firestik antenna, Hi-Lift jack...
lutzke21 is offline   Reply With Quote
Old 04-27-2006, 05:10 AM   #21
neZZr
neZZr's Avatar
Yes, if you look closely there are two fuse slots. One to fuse the existing circuit, the other for the new line.
SIRA 4x4 club
Old 04-27-2006, 05:29 AM   #22
tjsooley
i want to make a comsol that doesn't require you to remove the sound bar
[COLOR="Red"]______
l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_) [/COLOR]
[url]http://www.myjeepspace.com/profile.php?id=653[/url]
tjsooley is offline   Reply With Quote
Old 05-14-2006, 11:28 AM   #23
k8ysv
I would keep looking rather than buy one of those from NAPA at 18 bucks. I found them at the local Vato Zone for like 6 bucks. They had them in standard and mini ATA versions too.
2004 Patriot Blue Wrangler X, 33"x10.5" BFG Mud Terrains, 4WDH 2" lift with 3/4 inch spacers, 1" BL, 1" Brown Dog MML, Yukon 4.56 gears, Yukon Super 35, ARBs front and rear, Warn 9.5ti winch, GPS, MP3, Some hooks and lotsa skids.
k8ysv is offline   Reply With Quote
Old 05-15-2006, 05:21 PM   #24
TJgreg
After the idea from this thread, here's mine.
bought a shelf track (72") and 2 2.5" U bolts from lowes. External speaker is right next to the cb. I ran the wires down the shelf track then inside the molding of the A pillar. Ran the coax through the roll bar padding then out to my tail light mount. No visual obstruction either.
I had to cut down the U bolts a bit, as well the shelf track, and also had to drill a few holes in the track, but other than that it was a cinch.
Semper Fi
Old 05-15-2006, 05:29 PM   #25
98TJSport
does it get in the way of the top clamps?
Jeepless right now.
help me!!
98TJSport is offline   Reply With Quote
Old 05-16-2006, 09:06 PM   #26
TJgreg
nope, visors have full range of movement too
Semper Fi
Glock Forum
