DIY Swing out tire carrier Bumper - JeepForum.com
post #1 of 21 Old 10-11-2006, 08:43 PM Thread Starter
Ala05Unlimited
I have ordered all my parts to build a swing out tire carrier bumper. Can anyone give me some suggestions on how you built yours or what you may have done different or added...Post pictures if you like...Thanks
2005 SILVER Unlimited, Cobra 25LTD CB w/400 watt linear amp (yes I want to be heard), Wilderness rack, 8 KC daylighters...Coming Soon 4" Lift, Body Lift and more
(OIIIIIO) Real Jeeps have round headlights
Ala05Unlimited is offline
post #2 of 21 Old 10-11-2006, 08:55 PM
RockRunner85
Ummm if you've ordered your parts don't you already have the plan in mind. Not like you can change it too much your you'll have to order more parts.
I would look at different tire carriers availabe to buy and see what you like and don't like and go from there. I went with Jeeperman and really like how its built. If I was building from scratch I would base it off theres.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #3 of 21 Old 10-11-2006, 09:24 PM Thread Starter
Ala05Unlimited
Yes I have all my ideas planned out. I am going to have it mount to the tail gate on a hinge system, two Jerry can mounts, Hi jack mounts, CB and KC light mounts.
post #4 of 21 Old 10-12-2006, 06:37 AM
dr hook
heres mine, but it's bumper based.
Lifted ZJ with stuff.
dr hook is offline
post #5 of 21 Old 10-12-2006, 07:12 AM
EaglesSJ
EaglesSJ's Avatar
Heres mine I built from 1/4" materials. Its now for sale
EaglesSJ is offline
post #6 of 21 Old 10-12-2006, 08:32 AM
jonzer12
I am not quite sure I understand, you said you were going to build a "swing out tire carrier bumpber that mounts to the tailgate". DO NOT mount your planned jerry can moutns, etc to the tailgate, build it off the bumper has the tailgate can't support much weight.
jonzer12 is offline
post #7 of 21 Old 10-12-2006, 09:28 AM
dieseljeep
When you get your parts, go ahead and throw them in the garage & let them collect a little dust. You haven't done nearly enough homework yet. Save yourself money, heartache & trouble and wait till someone can put you back on track.
dieseljeep is offline
post #8 of 21 Old 10-12-2006, 09:57 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
At the top of the Fabrication Forum main page there's a sticky about a rear bumper buildup. The writeup is decent but the guy who wrote it is a real jerk sometimes.
BESRK is offline
post #9 of 21 Old 10-12-2006, 10:47 AM
Bigbob
Bigbob's Avatar
I noticed the same. It seems like the moderator of this forum would ban those type of poster/posers. bob
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #10 of 21 Old 10-12-2006, 11:52 AM Thread Starter
Ala05Unlimited
Now, about mounting to the tail gate. The bumper will be mounted in the stock location, but I am adding a bracket to the tail gate. This giving it more support and hopefully stop the rattling that is common with swingout bumpers. I been doing my homework for awhile, just though I could get alittle more input.
post #11 of 21 Old 10-12-2006, 01:55 PM
Psyker
Build it right and you wont need anything except the spindle and the latch.
Personally I used a screw-type latch when I built mine (cherokee, so no tailgate points to use) with rubber grommets at the screw. I have had no rattles, vibration or anything like that.
Rattles come from poor design, measurement and construction. Take your time, make tolerances close, weld well and you wont have problems.
Call Sign: KF4ZHT
'96 Green XJ SE - I6, AX15, NP231, 2.5" Lift
'90 White YJ - 4 squirrels spinning a toothpick (i4 w/ax5) - WIP
Psyker is offline
post #12 of 21 Old 10-12-2006, 03:24 PM Thread Starter
Ala05Unlimited
Thank you...
post #13 of 21 Old 01-29-2009, 11:52 AM
turbogus
1978 CJ5
On my rig, '78 CJ 5, I built a security locker box that I've bolted to the floor in place of the rear seat (who can fit on that rear seat anyway) and my oversize rear tire mount bolts through the sheet metal tailgate to the locker box that is supported from the floor of the Jeep. (Note my CJ doesn't have a tailgate)
turbogus is online now
post #14 of 21 Old 01-26-2010, 07:41 AM
jesseleikerjeep
I noticed this as well...and his hands are always all "grinding wheel'd" and dirty....
-Jesse
jesseleikerjeep is offline
post #15 of 21 Old 02-28-2011, 08:56 PM
CMOfoSHO
im buildin a tire carrier soon these have gave me a good picture for it. thanks guys
CMOfoSHO is offline
Leans' swing out tire carrier Leans93 Fabrication Shop 23 06-05-2010 05:14 PM
Swing out tire carrier on a stock bumper? grnsanddemon Fabrication Shop 2 09-01-2009 10:37 AM
Body Armor 54" Rear Bumper w/ Swing Away Tire Carrier - weight? VanBCguy General Jeep & Off-Road Equipment 1 07-20-2009 09:12 AM
Swing out tire carrier SAJeep Fabrication Shop 2 11-10-2003 06:13 PM
Swing Out Tire Carrier mitchj01 Fabrication Shop 10 10-09-2003 10:38 AM
