DIY rockers - JeepForum.com
post #1 of 5 Old 11-14-2003, 08:58 AM Thread Starter
Tyler Dirden
DIY rockers
Ok, I have the steel, sized, cut, and ready to go on the Jeep.
I want to make the head of the bolt flush with the rock rail. I'm thinking of using flat head socket screws 8-32 x 1/2 and some bolt to be named later.
Will these be strong enough (i'm planning to use 6 or 8 on the body and a few more on the under-side of the Jeep, along with one or two mounted directly to the frame mounts)
(grainger part number 3G770)
2003 Rubicon
'El Negro'
Tyler Dirden is offline
post #2 of 5 Old 11-14-2003, 10:10 AM
dzp
dzp's Avatar
Really need to post some pics.
I think I understand what you are saying, and I think it should work. I would add more bolts if you are counter sinking the heads, as that usually means each is holding on with less material.
IMO, I wouldnt put any on the underside, as they wont help much and would just be more work.
The 3 body mounts are perfect for mounting to. Be sure that you dont connect the rockers directly to the frame, but btwn the tub and the rubber isolaters.
Tyler, Texas
97 TJ, Red, 33" MTR's, Locked F/R, D30/Ford8.8, JKS Disco's, DT3000's, tinted Sailcloth top, 8k Ramsey, Custom bumpers/armor, Ramps 890 on 25degree ramp.
dzp is offline
post #3 of 5 Old 11-14-2003, 10:18 AM Thread Starter
Tyler Dirden
Excellent tips. Thanks.
I also realized that #8 screws are gonna be pretty small... Too small. I'm going to try to get 5/16-18 button head or 1/4-20 if I go for flat head.
These rails are gonna have a step on them eventually, so maybe I don't even need the flathead (and the added work of countersinking them). Hmmm.
2003 Rubicon
'El Negro'
post #4 of 5 Old 11-14-2003, 02:20 PM
dzp
dzp's Avatar
I wouldnt. All of the contact should be on the bottom of the rocker. Any added work that does not give added protection, then I wouldnt do it, IMO. Just run 8 or 10 3/8" bolts in the side, and call it done....
Tyler, Texas
dzp is offline
post #5 of 5 Old 11-17-2003, 05:46 PM
Richie
I would think 8/32 would be vastly undersized. All the rocker guards I have seen are 1/4 or 5/16 bolts...
97 TJ, 97 ZJ, 01WJ
Richie is offline
What's behind your rockers? SimonTuffGuy General Jeep & Off-Road Equipment 15 04-15-2009 07:58 PM
New Rockers Natter4WD Fabrication Shop 3 05-18-2007 03:39 PM
AEV Rockers? RUB1CON General Jeep & Off-Road Equipment 8 02-14-2006 04:23 PM
My new rockers Tri_X_Troll Fabrication Shop 1 06-05-2005 03:25 PM
amv v8 rockers jeepjimmy Engines & Drivetrain 3 01-12-2002 08:45 PM
