#1 | |
Insert Witty Title Here
DIY Rear Bumper
Simple bumper really
3/16x5x2x80 rectube - main body and wrap around 3/16x2x24 flat stock - bottom frame tie in 1/2x24 round stock for safety chain hooks Already had a receiver, but next time I would probably make the receiver. ![]() ![]() ![]() Still need to remove a broken bolt on the bottom side of the frame and add in the bottom frame tie-ins.
#2 |
And some build pics along the way
I was actually tempted to leave it like this... ![]() ![]() But common sense kicked in... With a 15° angle ![]() ![]() ![]() ![]() Still not enough, so then to 30°... ![]() ![]() |
#3 |
But it still did not look quite right so I chopped off the leg and put another 30° bend in it.
#4 |
Two more rear cross member ties
![]() ![]() ![]() ![]() Notched for receiver and welded in ![]() ![]() ![]() |
#5 |
#6 |
Nice build. Good job!
#7 |
good work. i like how you put the trailor plug in the bumper.that gives me the ideal to put mine there too.
#8 |
You are my new favorite poster. I have been looking for pics of how people attach their bumpers and you are the first person I have seen to do so. I still have yet to get a chance to yank off my rear bumper to really get a good look so this helps out a lot.
Help build a complete visual database of ORV Trails |
#9 |
Thanks. Yes, I do plan on making a tire carrier - with 35-37's in the future, I have no choice.
#10 | |
I will give you the fore warning: with only a 2" section in the rear bumper, the depth of the trailer plug comes into play. You will need to ensure the trailer plug lines up horizontally with the hole in the cross member so the wires do not need to make a sharp turn and get cut as they transition between the rear cross member and the bumper. The holesaw used to mount the socket was 1 3/4" (standard 7 way semi plug). The holesaw on the rear of the bumper was 1 1/2". All was deburred and the rear facing hole had to be opened up with a grinder slightly as the socket itself is not round exactly. |
#11 | |
FYI 1 3/16" bolt centers vertically for all cross member pieces Horizontally, in order not to need to jockey with the fuel tank: 6" center to center on the left 6 1/4" center to center on the right |
#12 |
Finally removed the broken bolt and installed the bottom frame tie-ins.
![]() ![]() And installed my safety chain hooks shown on the outside for viewing purposes ' ![]() and installed ![]() ![]() |
#13 |
![]() You know, you COULD have left it like that, then you could really get back at those idiot drivers who like to tailgate the hell outta you. Put a nice scratch all up and down their car ![]() Bumper looks really good though. You did a great job ![]() |
#14 |
GROUND POUNDER
It does look really good! Nice work!
One question, is that plug water tight on both sides? If not, the bumper will fill up with water. My buddy just removed a home made bumper from his Scrambler and a small crack allowed it to fill about 1/2 way up with water. I was suprised at how small the crack was. If it's not water tight, you may consider drilling a small hole or two in the bottom of the bumper to allow it to drain... just a thought. ![]()
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#15 |
Wicked cool setup!!
![]() ![]() Right on ~ gives us building our own, something to achieve!! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
