DIY Laser alignment setup for Plasma system - JeepForum.com
post #1 of 3 Old 08-30-2013, 05:54 PM Thread Starter
rescueweasel
I recently added on a laser alignment system for my Precision Plasma table. I took a drill press laser alignment kit and modified it a little to work with my plasma system. It took about 15 minutes to make the mods and get everything hooked up.
I drilled an tapped a couple of small holes in the plasma torch mount so that I could lock down the laser system. The laser system was nearly a perfect fit. It was a little too thin for a perfect fit. I used some foam with a thickness of .19 and cut it too fit on top of the laser system.
This made the system a perfect snug fit. The screws keep things aligned and allow repeat-ability if the mount is removed and re-installed.
The system was easy to align. While a laser is not needed its a neat tool add on for $30 bucks that makes aligning a starting point a little easier, and in the rare case things get messed up during a cut, with pin point cross hairs you can get back to a known point.
I saw some other commercial products from $70 - $199 going to give this a try and see how it works.
CNC Plasma Project:
CNC Router Project: www.cncrouterbuild.com
rescueweasel is offline
post #2 of 3 Old 09-02-2013, 10:06 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
That is pretty neat. I am jealous of your setup. I have an old Victor Journeyman Oxy-cet with the MKII EB guidance tracking package...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 3 Old 09-03-2013, 08:54 AM Thread Starter
rescueweasel
Thanks! It has taken several years to get to this point. We used to do a lot of frame off restorations and jeep builds and I did a lot of it with my oxy set up, and dreamed of the day when I had a plasma unit.
You know how dreams work once you get one thing you start wanting the next and so on. So now we have a great 4x8 plasma table and a portable unit and I have plans for a 5x10 in the next year or so, but who knows?
CNC Plasma Project:
