Die set size dilemma - JeepForum.com
post #1 of 9 Old 07-08-2013, 12:18 AM Thread Starter
Dumpsterfish
So I'm happy with the JD2 model 3, and want to dig in on a couple projects-tube doors, roof rack, rock sliders, flat fenders, etc.
Have limited funds, and can't decide whether to pick up the 1.5 or 2 inch die first. 2 seems necessary for sliders, but 1.5 seems right for everything else.
So my question is: could I make a decently strong rock rail out of 1.5" .120 wall? Anybody done something similar?
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
Dumpsterfish is offline
post #2 of 9 Old 07-08-2013, 12:01 PM
tjcj
I started with a 1 3/4" die first. Used it for a couple cages and sliders for Toyotas. Then when a couple guys wanted 1 1/2" tube fenders I had them buy the die and I just bent it up and welded them , and kept the die.
Sent from my XT881 using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 9 Old 07-08-2013, 02:32 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I agree.... 1.75 die is what I did first as well. It's a great middle of the road die for many projects. I think the only project you mentioned I wouldn't use the 1.75 would be for tube fenders as it may be a little big for some applications.
Tomb Raider is offline
post #4 of 9 Old 07-08-2013, 03:05 PM Thread Starter
Dumpsterfish
Hmm, hadn't considered that size. 1.75 .120 wall stand up to abuse in the rocks, ya think? If so, I think that's the move
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #5 of 9 Old 07-08-2013, 03:33 PM
tjcj
Ya it stands up to some pretty heavy abuse.
tjcj is offline
post #6 of 9 Old 07-08-2013, 05:46 PM Thread Starter
Dumpsterfish
Cool, thanks for the advice.
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
post #7 of 9 Old 07-08-2013, 06:51 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
1.75 x .120 wall is some pretty tough stuff. it is a very universal size.
and i have seen some people sleeve their 1.75 die with some 1.75 x .120 wall tube to basically make it into a 1.5 die. bend a piece of tube, cut it lengthwise in half and use the inner half to sleeve the Die down, and use a small straight piece cut in half on the shoe. weld some little tabs on the end to keep them in place, and you have turned your 1.75 die into a 1.5" die. Granted, it would be for limited use but it does work if you only need to bend 1.5 every once in a while.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #8 of 9 Old 07-09-2013, 06:28 AM
jason m
Nothing but the facts
jason m's Avatar
This, but I made out of 1.5" to bend 1.25". Works perfect just use more WD40. I don't weld any tabs I just let the pressure of the die clamp the tube in place and bend away.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #9 of 9 Old 07-11-2013, 09:01 PM Thread Starter
Dumpsterfish
1.75 ordered and on the way. Now for a trip to the metal supply place...
'01 TJ...stock
'89 YJ...SOLD
'95 YJ...SOLD
'13 JKUS...SOLD
