-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Die set size dilemma (http://www.jeepforum.com/forum/f37/die-set-size-dilemma-1546347/)
Dumpsterfish 07-08-2013 12:18 AM
So I'm happy with the JD2 model 3, and want to dig in on a couple projects-tube doors, roof rack, rock sliders, flat fenders, etc.
Have limited funds, and can't decide whether to pick up the 1.5 or 2 inch die first. 2 seems necessary for sliders, but 1.5 seems right for everything else.
So my question is: could I make a decently strong rock rail out of 1.5" .120 wall? Anybody done something similar?
tjcj 07-08-2013 12:01 PM
I started with a 1 3/4" die first. Used it for a couple cages and sliders for Toyotas. Then when a couple guys wanted 1 1/2" tube fenders I had them buy the die and I just bent it up and welded them , and kept the die.
Sent from my XT881 using JeepForum
Tomb Raider 07-08-2013 02:32 PM
I agree.... 1.75 die is what I did first as well. It's a great middle of the road die for many projects. I think the only project you mentioned I wouldn't use the 1.75 would be for tube fenders as it may be a little big for some applications.
Dumpsterfish 07-08-2013 03:05 PM
Hmm, hadn't considered that size. 1.75 .120 wall stand up to abuse in the rocks, ya think? If so, I think that's the move
tjcj 07-08-2013 03:33 PM
Ya it stands up to some pretty heavy abuse.
Dumpsterfish 07-08-2013 05:46 PM
Cool, thanks for the advice.
underpowered 07-08-2013 06:51 PM
1.75 x .120 wall is some pretty tough stuff. it is a very universal size.
and i have seen some people sleeve their 1.75 die with some 1.75 x .120 wall tube to basically make it into a 1.5 die. bend a piece of tube, cut it lengthwise in half and use the inner half to sleeve the Die down, and use a small straight piece cut in half on the shoe. weld some little tabs on the end to keep them in place, and you have turned your 1.75 die into a 1.5" die. Granted, it would be for limited use but it does work if you only need to bend 1.5 every once in a while.
jason m 07-09-2013 06:28 AM
This, but I made out of 1.5" to bend 1.25". Works perfect just use more WD40. I don't weld any tabs I just let the pressure of the die clamp the tube in place and bend away.
Jason.
Dumpsterfish 07-11-2013 09:01 PM
1.75 ordered and on the way. Now for a trip to the metal supply place...
The time now is 09:07 AM.
