Dez Racer XJ build - Page 10 - JeepForum.com
post #136 of 427 Old 02-12-2008, 11:49 AM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
Too bad you are not in Cali Could use some help, sounds like you have the perfect background. There are people that travel from Texas to race Jeepspeed so get to building! You will not be disappointed. I am looking into the halon still but it is almost a sure thing we will have a system in place before we race. Thanks for the advice, much appreciated and best of luck!
Originally Posted by ProMod1385 View Post
Too bad your not in MN. I worked in ProMod Drag racing and know a thing or two about fab and race prep, i would love to give you a hand. The jeep speed class intrigues me and it might be the best way for me and a couple of buddies to race at Baja I am thinking if we built one here in MN we could keep it in AZ at my families vacation house and travel for races.
I noticed a dialog about halon systems a couple pages back. If you can afford them and they don't push you over your 4K weight limit i would say to go for one! I have seen a couple guys burn up $100,000 race cars because there class didn't require halon and they were not running them. (one was a supercomp car and the other a fast door car) I had one crewman's daughter accidentally hit the lever in the garage and set off the bottle one time, it was a mess so make sure you keep the cotter pin in the bottle when not racing the car. Otherwise they are cheap piece of mind both from a $$$ point of view and from a safety point of view.
got the dash mocked up, made one set out of regular mild steel but we are most likely making the final product out of 6061 Aluminum, we have all the switches and buttons, just need to assemble and wire it all when I get some time, I'll take some pics of the mild steel dash in a bit:
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #137 of 427 Old 02-23-2008, 09:55 AM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
skullver is offline
post #138 of 427 Old 02-24-2008, 10:34 AM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
skullver is offline
post #139 of 427 Old 02-24-2008, 11:49 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Great progress, can wait to see it race.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #140 of 427 Old 02-24-2008, 12:08 PM
aircruiser
aircruiser's Avatar
she's looking purty!
aircruiser is offline
post #141 of 427 Old 02-24-2008, 04:29 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
Thanks guys! wife is due any day so on call! got the removable(to service the fuel cell) section of the tire rack/bumper almost done, may add some dimple die plates and a few more small tubes:
skullver is offline
post #142 of 427 Old 02-24-2008, 04:45 PM
Comanche_
Looks amazing. :twothumbsup:
Originally Posted by Z0NAJEEP View Post
With more stupid comments? Two retards don't make a right.
Comanche_ is offline
post #143 of 427 Old 02-24-2008, 05:21 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
Thanks much!
Got the tires in and have plenty of room for a spare D/S and highlift underneath:
plenty of room for dual optimas and other spares:
the 9" is getting some silt drain holes, a fill plug/vent, and a much needed drain plug in the bottom, no way to drain them(easily) without pulling the 3rd member, so had to do that for frequent gear oil changes/inspections:
skullver is offline
post #144 of 427 Old 02-26-2008, 12:16 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
fill plug and vent combined, anybody see a problem with this set-up?
skullver is offline
post #145 of 427 Old 03-01-2008, 02:24 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
decided to start on the front leaf spring hangers while I had the rear end out...again. What a major pain they were, even after searching out the spot welds and drilling them out, they were stubborn! Those factory spot welds are surprisingly hard to tear without drilling them out completely.
Whats left of the psgner side hanger:
the start of the inside bolt access tube:
the start of the inner mount itself, there will be a piece of .250" plate formed into an L for the outer mount, and a piece of plate along the roof/floor.
skullver is offline
post #146 of 427 Old 03-01-2008, 04:34 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
the outer "cup" for the inner leaf spring mounting surface, made from .250" cold roll plate, the piece and the template are upside down relative as the top portion had to be almost vertical:
skullver is offline
post #147 of 427 Old 03-01-2008, 05:27 PM
aircruiser
aircruiser's Avatar
oh! oh! i know!!
it needs to be under the jeep to make the jeep move!
did i get it right?
post #148 of 427 Old 03-01-2008, 08:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Love this build! Super work!
BESRK is offline
post #149 of 427 Old 03-05-2008, 10:20 AM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
Thanks Besrk! Much appreciated! After a few different versions of parts,and many hours of wasted time, and many chunks of wasted steel, I think I finally finished up my final design, aside from the outer spring mount that will be a single formed piece of 3/16" cold roll that should be here today, cold roll is hard to find around here thicker than 20 guage so I have to order from online metals.
here are the pieces that will make it up:
the thru tube and inner spring mount:
the main piece and how they go together but upside down, the box is a single piece of 3/16 with 2 90 deg bends
and all the parts together, should be close to installing them this afternoon but still have to make the mirror image for the other side, that will be easy as I kept and labeled all of my cardboard templates for each piece and the version, currently at version 3
skullver is offline
post #150 of 427 Old 03-05-2008, 04:43 PM Thread Starter
skullver
Tarpitz
1991 XJ Cherokee
got them all formed, welded, and mocked up, perfect fit! The top portion of the plate with gussets will be tied to the cage from the inside, should never have a problem with those:
from the inside of the "frame" rail:
lighting is a little screwy with my camera
skullver is offline
First aid kit-Buy it or build it? GhostRiderLJ General Jeep & Off-Road Equipment 36 09-15-2009 06:06 PM
Who will build this for me? stunner Fabrication Shop 16 08-05-2009 12:39 AM
Sub Build. Niceface Audio, CB & Ham Radios, GPS, & Electrical 29 06-01-2009 07:36 PM
What to build with this? TEXASRAM Fabrication Shop 7 04-18-2008 03:55 PM
First Build Pantophobia Tires & Wheels 0 11-09-2006 07:58 PM
