#1 | |
Tarpitz
Dez Racer XJ build
sorry about the photo link problems
edit: thanks to jeff in PA scroll down for click free!)how they started, 1985 pioneer chassis with 1991 HO drivetrain donor ![]() the cage 1.75" x .120" DOM: ![]() the motor donor experiencing some sawzall: ![]()
#2 |
Tarpitz
started with a rustys 8" long arm kit, ended up removing it and selling it for the much stouter Full Traction long arms
![]() also tried RE drop brackets and adjustable arms, they were also removed/replaced ![]() rolling mock up with final suspension and glass fenders ![]() |
#3 |
Tarpitz
ford 9" showed up, 35-spline shafts and full steel spool:
![]() MORE bombproof block mounts: ![]() ![]() 9" under and some test fitting with tires" ![]() ![]() |
#4 |
Tarpitz
The D30
![]() hydraulic bumps ![]() and SAW shocks ![]() ![]() |
#5 |
Tarpitz
bump bracing and fuel cell mock:
![]() shock mounts mocked and ready for plating ![]() ![]() ![]() with all shocks in ![]() ![]() |
#6 |
Tarpitz
2wd beam
#7 |
Tarpitz
some plating:
![]() trackbar mount: ![]() removable engine xmember and shock mount bracing: ![]() ![]() ![]() |
#8 |
Tarpitz
as it is raining right now here in Cali, trying to find something to do on the Jeepspeed, gotta keep steady progress or it will slip away.
Blah blah blah blah. my Jeepspeed build thread: http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/ |
#9 |
Thats pretty intense, you should post this in the XJ section as well. It will probably get a lot of appreciation there.
#10 | |
Tarpitz
Blah blah blah blah. my Jeepspeed build thread: http://www.jeepforum.com/forum/showthread.php?t=367176 |
#11 | |
#12 | |
Tarpitz
Chris
#13 |
GROUND POUNDER
Nice build! Keep coming with updates!!
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#14 |
Tarpitz
after a little massaging got the new front end in and it rolls again, next we are going to tackle the seats and harnesses.
#15 | |
2011 Chevy Silverado ext cab z71 1988 JEEP Comanche 4x4 shortbed: 4.0L w/ 5spd 6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s High School Jeepers #15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
