Deburring 1.75" OD DOM Tubing - JeepForum.com
post #1 of 10 Old 05-10-2011, 10:42 AM Thread Starter
jatepper
I'm looking to see if anyone knows of a special deburring tool that will deburr the inside and outside of DOM tubing once it has been cut. I have seen those little hand reamers, but that looks to be like a lot of work as I plan on cutting hundreds of small pieces.
I have found deburr tools for stainless steel, but will this work for regular DOM? What tricks have you guys found that works well?
http://www.toolfetch.com/Category/Pi...ools/70075.htm
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #2 of 10 Old 05-10-2011, 11:01 AM
tangotag
Those only work for 90 degree cuts. You would need to do lots of straight 90s to make it worth your while.
We use bench mounted belt sanders and only debur and grind back the outside edge to prep for welding. I can't think of too many 90 degree tubing joints most end up with fish mouth ends at least in our shop.
tangotag is offline
post #3 of 10 Old 05-10-2011, 11:20 AM
'92 vegas YJ
if your trying to de-bur the inside for say a weld in bung or something i use dremel. belt sander or grinder with a flap disk work for the outside.
i know it sucks if you say you have hudreds of small peices but thats what i use in my small 2 car garage
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is offline
post #4 of 10 Old 05-10-2011, 02:25 PM Thread Starter
jatepper
Yeah, I would be doing 90* cuts. It is not related to jeep or vehicle stuff.
jatepper is offline
post #5 of 10 Old 05-10-2011, 02:50 PM
rlockwood
hard to beat a lathe for 90* cuts..
http://www1.mscdirect.com/cgi/NNSRIT...-SearchResults
these work well for ID, and you cant really beat a grinder/bench sander for the OD.
rlockwood is offline
post #6 of 10 Old 05-10-2011, 03:54 PM
wushaw
Rockin jeep
wushaw's Avatar
Or a small drum sander chucked into a straight die grinder.
wushaw is offline
post #7 of 10 Old 05-10-2011, 06:07 PM
jason m
Nothing but the facts
jason m's Avatar
http://cgi.ebay.ca/Deburring-Tools-A...ion_Parts_Gear
http://cgi.ebay.ca/SWIVEL-HEAD-HAND-...efaultDomain_0
Used these in the past with good results, I still have the small red handle one. The second one I posted.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #8 of 10 Old 05-10-2011, 06:35 PM
Jim1611
Jim1611's Avatar
How many are you wanting to deburr Jeremy?
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #9 of 10 Old 05-10-2011, 07:57 PM Thread Starter
jatepper
A couple hundred Jim. For various different items that I sell. I need them all cut a 2" in length.
jatepper is offline
post #10 of 10 Old 05-10-2011, 08:52 PM
Jim1611
Jim1611's Avatar
If you're going to continue doing this Jeremy I've seen dual spindle outfits that you can chuck a counter sink in for deburring the inside then there's another tool for the outside. You just hang on to the part by hand and the go from one spindle to the next.
Also don't you have a drill press? That would also work. Just chuck the beburring tool in the spindle and use a vise on the table to hold the part. You could do the i.d. on them all then do the o.d.
My build thread
Jim1611 is offline
2"x2"x1/8" tubing for carrier squigy123 Fabrication Shop 15 07-31-2010 11:31 AM
whats the tightest 90 you can do with 1.5" HREW tubing? Goobersbro Fabrication Shop 5 04-03-2010 08:00 PM
What tubing to use skywalker2117 Fabrication Shop 5 02-10-2009 06:49 AM
Pre-fab tubing mike481 Fabrication Shop 5 08-09-2006 12:34 AM
Tubing Bender, Help? gumcrew2 Fabrication Shop 10 02-08-2006 10:08 PM
