#1 | |
Dawson's M-416 Build
Look what I found!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The guy I bought it from had a new tub fabricated to the same specs as the original, just made out of 1/8" steel this time around. The sides and bottom are made of a single sheet of steel with the front and rear welded on. The front and rear sheets need to be cut, as you can see in the pics. The tub isn't bolted to the frame yet either. I'm going to need to weld some angle iron onto the bottom in order to bolt the tub to the frame. I'm live in the DFW Metroplex so if any of you guys live here and can help i need it!: Step 1: Cutting. I need to find someone with a cutting torch or plasma cutter. I'll bring beer and reimburse for any costs incurred. Disclaimer: The author of this thread is not responsible for any accidents caused by anyone drunkenly wielding a cutting torch/plasma cutter. Step 2: Welding. I need to find Someone with a MIG or TIG welder and welding skills. Again, I'll provide beer and reimbursement for any cost incurred. Disclaimer: The author of this thread is not responsible for any accidents caused by anyone drunkenly wielding a MIG/TIG welding instrument. Step 3: Sand Blasting. I used ICA to sandblast and powdercoat my PSC Rocker Knockers so I'll probably use them again for this sandblasting. That is unless anyone knows of a shop that'll sandblast for cheap. Please let me know! Step 4. Paint. I'll probably buy a pneumatic paint gun and do this on my own. Thanks in advance for comments/suggestions. I really need help from those of you who have welders/cutting equipment. Thanks, Dawson
Last edited by dawsonc61; 10-12-2008 at 06:24 PM.. Reason: Metal is 1/8" thick, not 3/16" as originally estimated. |
#2 |
I wish I could find something like that.
Nice looking trailer. Keep the pics coming. |
#3 |
I'd love to help ya. Have you weighted it yet? The 3/16" is gonna be awfully heavy. With 3/16" there would be no need for a frame.
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#4 |
#5 |
Nice!! Great Find ~~ Have fun !!
#6 |
Ha ha. True...i overestimated on the thickness of the metal. It's only 1/8", but still pretty thick. I don't know what the original thickness was. Hmmm.
#7 |
i dig the trailer, but i like the sticker in your back window better!!!
#8 |
Well my new buddy Keith and I did a little work on the trailer yesterday evening. We mounted the tub to the frame with some 3/16" tabs and 1/2" grade 8 bolts.
![]() ![]() ![]() Then we mounted the old trailer lights and and wired it up so I could drive home safely! This is temporary. I think we will build a bumper and put lights directly in the bumper. ![]() When I got home, I took a cutting wheel and removed the excess metal from the front and rear of the tub. Before: ![]() After: ![]() Anyway, just keeping everyone updated. A BIG thanks to Keith Maddox for his help and expertise. |
#9 | ||
Ditto X 100
#10 |
looks solid, I wish I could find one.
-Morgan '00 Silverstone 2 Door XJ Utah Jeep Crew Member #119 My Webshots New Build Old Build |
#12 |
The NOBAMA sticker has been a big hit. Lots of thumbs up on the road. I did get the finger the other day from a dude in a Prius....go figure!
#13 |
What are you planning to use it for? Hauling, camping, everything?
2003 TJ Wrangler 1981 CJ-7 1959 Willys Wagon L6-226 1955 Willys Wagon SBC Last edited by garthbrown; 10-19-2008 at 01:34 PM.. Reason: Misread prior post... |
#14 |
Camping, once finished It will have a lid and a RTT on top. Onboard with be a 40 gal water tank, 3 Energizer deep cycle marine batteries (run in series to a power inverter), 2 propane tanks, a small kitchen compartment with burners and hot plate, and some sort of LED outdoor lighting system. I'm sure I'm leaving off things but you'll see it develop.
#15 |
Well I've been messin' around with Google "SketchUp" and here's what I've come up with:
![]() ![]() ![]() ![]() I'll be designing the interior of the tub next, including a water tank, deep cycle batteries, sliding runner with kitchen components and propane setup. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
