Dana 44 shaft length - JeepForum.com
post #1 of 22 Old 02-04-2014, 02:16 AM Thread Starter
baktie_91YJ
So I'm planning on building a one ton dana 44, and I need some info. What is the difference in shaft length if the pinion yoke is centered on the axle? I would like for my driver and lassenger side shafts to be the same length for ease of replacement. From what I've found on the XJ 44's( they seem centered) the difference is a 1/2 inch longer on one side, something like 28 5/8 and 28 1/8.
Also is there a problem running with the pinion slightly off center if I do this?
baktie_91YJ is offline
post #2 of 22 Old 02-04-2014, 06:23 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Dana 44s are generally considered 1/2-3/4 ton axles.
In order to have equal-length axles, the pinion will have to be offset. Many axles out there actually have offset pinions.. no problem.
BESRK is offline
post #3 of 22 Old 02-04-2014, 12:54 PM Thread Starter
baktie_91YJ
BSERK,
Do you know how much the offset will have to be with a Dana 44?
post #4 of 22 Old 02-04-2014, 04:53 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Not off the top of my head. Over on Pirate, I think Billavista wrote up a D44 article that may have the info. I know he did a great writeup for the D60 several years ago..
BESRK is offline
post #5 of 22 Old 02-04-2014, 07:52 PM Thread Starter
baktie_91YJ
Okay thanks. If I recall correctly the XJ dana 44 pinion is centered so I thing it may only be 1/4 of an inch offset
post #6 of 22 Old 02-05-2014, 06:40 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I can measure on the weekend if you like.. I've got a XJ D44 sitting on the shop floor..
BESRK is offline
post #7 of 22 Old 02-06-2014, 08:48 AM Thread Starter
baktie_91YJ
If you can that would be great! can i get driver and passenger shaft length, distance from flange to pinion on both sides, and distance from backing plate to where the tube meets the housing on both sides?
post #8 of 22 Old 02-06-2014, 03:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
No longer has regular backing plates. It's got a disk conversion from a ZJ (IIRC).
BESRK is offline
post #9 of 22 Old 02-07-2014, 09:43 PM
ltrail
1984 XJ Cherokee
Would likely be better off with a ford axle such as an 8.8 or 9". I had both eb9 and full size 9" I ran in my xj. Equal length shafts, the 8.8 is narrower than an xj axle I've always wanted to get one and use both long side shafts to stretch of out and have equal length shafts. D44's aren't that great and are a tad rarer, ford are a dime a dozen and stronger.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #10 of 22 Old 02-08-2014, 05:27 PM Thread Starter
baktie_91YJ
BESERK, doesnt have to be backing plates as long as the difference in tube length is measures
post #11 of 22 Old 02-08-2014, 05:27 PM Thread Starter
baktie_91YJ
ltrail normally I would agree with you, but this is going to be a full float dana 44 with 14 bolt shafts
post #12 of 22 Old 02-09-2014, 05:31 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
These are the measurements from the inside of the axle tube flanges-to the centerline of the pinion...
26.25" and 28"
BESRK is offline
post #13 of 22 Old 02-09-2014, 06:54 PM Thread Starter
baktie_91YJ
Thank you!
post #14 of 22 Old 02-10-2014, 07:33 PM
ltrail
1984 XJ Cherokee
Does someone make a large 30 spline 44 spool/locker? Both axles are 30 spline but 14v shafts are a bit larger diameter. Would be much better off doing a 609. Use 35 spline spool for the ford 9 and tube a 9 to use d60/70 35 spline shafts. I think it is a lot harder to do what im lead to believe you are doing. Furthermore, a d44 r&p won't hold up to 1ton abuse.
ltrail is offline
post #15 of 22 Old 02-11-2014, 06:17 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Why not just run a rear 60 or 14Bolt? They're relatively cheap. Many full-floater 60s are only 30 spline, so you'd need to search around, or bore the spindles for 35 spline axles.
14Bolts are cheap and pretty much bulletproof. If you're running big enough rubber, ground clearance isn't too bad, after you shave the bottom lip off.
While it is possible to build a pretty strong D44, a stock (read cheaper) D60 is still stronger.
BESRK is offline
