dana 30 axle truss - JeepForum.com
post #1 of 9 Old 10-16-2004, 11:32 AM Thread Starter
js2
js2's Avatar
dana 30 axle truss
I am looking to truss my front dana 30 anyone have any pics ? I want to fab it myself any help much appreciated!!!! Thanks
75 cj5, built 304, t15 tranny, dana 20 transfer, dana30 front, dana44 rear,both w/limted slips & 4.56 gears, soa lift
js2 is offline
post #2 of 9 Old 10-18-2004, 03:43 AM
rockdw72
rockdw72's Avatar
http://www.stu-offroad.com/fabbed/fab-1.htm
I kind of like this one
33 muds locked and whatevers needed
rockdw72 is offline
post #3 of 9 Old 10-21-2004, 08:08 AM
BamaJeeper
BamaJeeper's Avatar
Why in the helll would you???
Out of the darkness comes light.
BamaJeeper is offline
post #4 of 9 Old 10-21-2004, 11:53 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I was kinda wondering the same thing myself. Normally, an axle is trussed to resist axle tube bending forces associated with either torque (like a dragster where the tires are trying to drive forward so hard they can bend the axle tubes forward) or upward force (as in jumping the vehicle where the hard landings can bend the axle tubes upward). Since your average Jeep is neither a pavement pounding dragster nor a Baja Racer (I assume) then you really don't need one unless you just want it for looks. Plus, it takes away from ground clearance.
BESRK is offline
post #5 of 9 Old 10-21-2004, 11:12 PM
Qman
i would like to know how they are turning 44x18.5 hawgs a D60 would have a hard time holding up to those tires...
Qman is offline
post #6 of 9 Old 10-27-2004, 11:04 PM
Jnmielcarek
Have you looked into a front axle upgrade? I'm currently working on a dana 44 for the front of mine. My dana 30 housing and tubes have been the least of my hassles. Broken carriers, u-joints, and shafts have been the weak points of a Dana 30 for me. I have, however, gotten my Jeep airborn on several occasions. Three weeks ago I launched the front end about an honest five feet when coming out of a dry pit. (Thought I was going to set the Jeep on the back tire carrier). I have not bent the tubes as of yet and I'm lugging around a heavy 360 V-8. I ALWAYS have the tires aired down when I'm off-roading and that helps cushion the landing a lot.
'81 CJ-7, 35" X-Terrains, Hopped up AMC 360, T-18, Dana 300 w/twin stick, Model 20 w/Lock-Right & Mosers, Aussie locker front, Warn x8000i winch, York onboard air, many other goodies.
"It's not a party until something gets broke!"
Jnmielcarek is offline
post #7 of 9 Old 10-31-2004, 02:48 PM Thread Starter
js2
js2's Avatar
Yes , I have been looking into axle swap as well. I want to do both front and rear to widen stance and gain stability. I have blown 2 u-joints since purchase 1 each time I have wheeled it. Clearly the 30 isn't up to the task!!! I was just looking for something cheap I could do to beef up what I have and possibly help on the resale side to help pay for new axles. I jumped my jeep first time out. I didn't even come close to 5 feet, Maybe 1 foot but both tires off the ground , does that count as a jump. I'm running the 304 with 44" tires aired down to 5 lbs. thanks for the helpful response.
js2 is offline
post #8 of 9 Old 10-31-2004, 05:10 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Jumping a Jeep isn't all that good for it. Jumping a Jeep with a D30 is looking for trouble. Jumping a Jeep with a D30 and 44" tires is begging for trouble. You need to have the video camera ready next time so you can capture the spectacular failure at the steering knuckles or spindles when the front tires fold up in grand fashion.. just talking a little smack 'cause it's Halloween..
BESRK is offline
post #9 of 9 Old 11-01-2004, 04:50 AM
BamaJeeper
BamaJeeper's Avatar
If you are gonna be jumping and want more track width then start looking for D60s or better yet 2.5 ton Rockwells.
You are asking WAY too much from a D30!
1996 ZJ, Dana 30 Axle truss nordictom Fabrication Shop 9 03-05-2010 11:08 PM
Dana 35 truss design inmate001 Fabrication Shop 2 10-26-2009 07:25 PM
LP Dana 44 truss E_ROCK Fabrication Shop 21 07-04-2009 04:58 PM
Truss for a Dana 35 KraZeDav Cheap Tricks & Fixes 6 05-27-2008 01:15 PM
Dana 44 truss awill110 General Jeep & Off-Road Equipment 0 02-08-2002 03:18 PM
