D44 double shear high steer arms. - JeepForum.com
post #1 of 6 Old 10-10-2009, 02:22 PM Thread Starter
ksheffer08
1981 CJ7
has anyone ever seen a double shear high steer arm for a dana 44? what I was thinking is a high steer arm that places the tie rod hole directly over the factory hole the running a heim between them. that way your leverage is being distributed through out the knuckle, not just coming from above the ball joints, which I would imagine puts a lot of stress on parts.
other than leaf spring clearance does anyone see a problem with this? I have access to a water jet so i think I'm going to give it a shot.
ksheffer08 is offline
post #2 of 6 Old 10-10-2009, 08:10 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen a few setups like that.. basically using a long bolt and spacers between the stock arm and the high steer arm.
There are also high steer arms with a second bracket bolted to the top that allow a double sheer setup without dropping the steering linkage below the high steer arm.
BESRK is offline
post #3 of 6 Old 10-11-2009, 12:13 PM Thread Starter
ksheffer08
1981 CJ7
Ive seen those for a 60, but do they make them for a 44?
post #4 of 6 Old 10-11-2009, 07:09 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Not sure.. I don't see why they wouldn't. The arms are a little smaller but I think there's still enough room.
BESRK is offline
post #5 of 6 Old 10-12-2009, 11:44 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
FWIW - I'd rather go with the second option. What's the point of going high steer if you're not really going high steer? And going psuedo high steer just to do a double sheer would be an expensive endeavor.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #6 of 6 Old 10-13-2009, 01:21 AM Thread Starter
ksheffer08
1981 CJ7
steering geometry.
Is this High Steer any good? dementedwombat Engines & Drivetrain 1 03-08-2009 06:36 AM
double helm joints on lower control arms? timritchieblue Fabrication Shop 6 01-06-2009 12:09 PM
High Steer kit for TJ?? WillRyan Tires & Wheels 4 04-21-2008 07:50 PM
dana 60 high steer arms renforcement jason m General Jeep & Off-Road Equipment 5 10-14-2007 10:37 PM
high steer mean green Tires & Wheels 3 02-25-2004 04:39 AM
