> General Technical Discussions
> Fabrication Shop
D-ring mounts on homemad bumper
08-07-2012, 06:21 PM
#1
I'm designing a bumper for my xj an I was wondering If I could put D-ring mount on the bracket i mount the bumper with? Does anyone already have a blueprint or plan for this, I've searched for the past hour and can't find the answer I'm looking for. Thanks for the help guys
I didn't know what I was Doing then, and I still don't now. I'm learning though.
My unneccesarily long build: http://www.jeepforum.com/forum/f22/night-krawler-build-1403164/
08-07-2012, 07:28 PM
#2
Thats how I mounted mine. 1/4 x 4" on the bottom of the unitframe with 1x2x6" with 3/4 hole welded to the bottom. The same place the factory style has its tow hooks. Ive also set my towbar to mount to them.
Ron
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
08-08-2012, 01:03 PM
#3
Any pictures? Either from when you did it or if you can snap some for me would e appreciated
08-09-2012, 07:49 PM
#4
The motivated way
Step 1 - remove stock bumper
Step 2 - Get a piece of paper, a pair of scissors, and a pencil. The paper needs to be 6" high and roughly 20" long (hint hint) cut out a notch for the fender support
Step 3 - Do a rubbing on the PASSENGER side of the frame rail. You should pick up 3 bumper holes, the 3 holes that would be holding the steering box on for the drivers side, and a larger hole at the back.
Step 4 - Transfer rubbing to a piece of metal (see step 2 for size)
Step 5 - Start Drilling holes
The easy way
Buy the from AJ's or Nates 4x4
Somewhere deep in the garage I have a plastic template from when I made my bumper, but I wouldn't know where to start looking.
Mine started as a rubbing also.
'00 XJ Sport, White - almost done for now...
'11 Town and Country - people mover :-(
Had:
'88 XJ Up Country, '01 XJ Sport, '08 KK Limited, '98 XJ Parts Donor, '07 XK Limited (the Stall-ander)
08-09-2012, 09:21 PM
#5
Thanks, I will probably do the "motivated way" how hard is it to take off the bumper. I'm sure I could figure it out, if just like a heads up
08-09-2012, 09:55 PM
#6
3 bolts per side. Metric. Maybe Torx, I can't remember.
Here's my original plate, made of 1/4" plate 6"x20"
I had a buddy laminate 2 other pieces of 1/4" plat to make a 3/4" thick clevis mount, then the same buddy welded a 5" piece of flat stock between the two, a cheap winch plate that came with my cheap winch flush to the front cross member, and I had a sub frame for a winch bumper.
That's when the hack job reattach of the whole front bumper minus cutouts for the clevis mounts came in. It looked like boiled dog turd, so I won't show you.
I also decided to learn to weld because I was starting to bother my buddy with my jeep addiction.
I made outer 'wings' for the bumper piece by piece out of 1/4", 3/16", and some 1/8" plate and some 2x3 box tube. I used a lot of cut off discs and rods.
Finally I hacked the center section of the original bumper to have a hybrid winch bumper look. I really liked that one for about a year.
Now it's 'finished' and all that other good stuff.
Mostly I want you to see how strong you need to make the mounts.
If you cheap out and only use a few holes you will shred the unibody.
The way I've mounted the bumper is about as strong as it gets with out welding it in place.
Good luck.
Had:
08-09-2012, 10:01 PM
#7
Alright, I will show you the boiled dog turd, and how it sits now.
I'm also now sitting on 5" and 33's - 2 years ago it was 2" BB and 235's
Had:
08-09-2012, 10:21 PM
#8
Looks a lot better now btw  and thanks, I will probably use this to guide my bumper build
08-09-2012, 10:32 PM
#9
I only ran that craptacular version for a week. It motivated me pretty strongly fab up the outer parts and run the hybrid center section. Frankly I thought it sucked and I spent all week in the garage at night sorting things out.
I like my current set up a lot now, but am considering selling it to start over. This time I'll cut into the front crossmember and recess the bumper back farther to gain approach angle.
Had:
09-20-2012, 08:38 PM
#10
Don't mean to revive this dead *** thread but I'm getting a late start on my bumper. While I'm saving up for my JCR DIY kit I want to pull Thai off this weekend. If I wanted to put drings on it would 1/4" steel be enough as long as I make them go down the frame with the tie in plate?
09-20-2012, 09:00 PM
#11
You will not TEAR the 1/4" plate, but you might bend it on a side pull. If you tie in across the front with even a piece of 2x2 and plate up the 1/4" to be 1/2" or 3/4" where the D ring slides thru like in post #6 2nd and 3rd photo you would be fine.
Or
Run up the frame and make a 3-4" plate that mounts across the front of the cross member to help support it. or something that goes under the frame where the sway bar attaches. A hard tug out of mud puts a pile of strain on the frame.
NOTE: If you are making home made recover points and your welding is rookie/amateur quality, then you are putting yourself and those around you at risk.
Had:
09-20-2012, 10:04 PM
#12
