cutting pipe or tube at steeper angles. - JeepForum.com
post #1 of 23 Old 09-29-2010, 11:03 AM Thread Starter
slafferty
I have a bunch of people wanting me to build them some bumpers. I built my stinger a few years ago, i didnt really cut the angle of the front to well, just hacked it and filled it in with welds. I dont want to build a bumper for someone else and it have a "hack" job. whats the best method for cutting >45degrees?
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #2 of 23 Old 09-29-2010, 01:21 PM
TXvodoo
1987 YJ Wrangler
Chop saw that's able to cut angles and a good abrasive blade.
TXvodoo is offline
post #3 of 23 Old 09-29-2010, 05:17 PM Thread Starter
slafferty
my chop saw only cuts 45 degree
MY BUILD THREAD
post #4 of 23 Old 09-29-2010, 05:52 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
porta band works well. grinder with a cutoff wheel can be used as well.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 23 Old 09-29-2010, 07:09 PM
Ironworker709
Ironworker709's Avatar
A little trick i've learned building handrails at work with no real chop saws or benders on site...
When need to cut an angle on pipe or tube,find something that has a long straight edge,like maybe a 2 foot framing square or anything that has a nice straight edge.......use either the sun or a bright light somewhere to make a shadow,place the straight edge under the light source on something like an edge of a table with something weighing/holding the straight edge down on the side you are not using the shadow.. or anything you can keep the very edge of you're straight edge shadow unrestricted,,use a marker or soap stone to figure the right angle you need off the shadow edge and run a line on that angle for a reference for the tube where you will be laying..on a floor..table..etc....put the tubing under the edge of the shadow where you need the cut at the angle needed,mark the whole side of the tube with a marker following that shadow line edge,then flip the tube and match the shadow to the angle again..mark that side,cut that line all the way around with a cut off wheel on a grinder or portaband or whatever you have to use..this gives you a very good reference line to make a clean cut if you marked it right,take you're time marking along the shadow.
I know it's kind of barbaric..but it does work if you have no other tools available to cut an angle on tube or pipe.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 23 Old 10-01-2010, 07:12 PM
johnny9
so does mine,but you can use clamps to set different stops,and hold it at extreme angles to cut it if your carefull..ive cut 5-6 inches down a 2'' od pipe holding it on angle on the dewalt chop saw,by setting something to keep you from hurting yourself and being very carefull..not something i would recomend for a newbie to cutting stuff..but we all gotta learn sometime.
ive had metal fly thru my shop wall a few times in the past but after a few times you get good at it lol..be carefull!
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #7 of 23 Old 10-01-2010, 08:22 PM
Warlord2
I used just wide masking tape last time. Mark some known points and connect the dots with the tape. As long as it doesnt kink, it will be straight. Once taped, then mark the line using the tape as a guide, or just leave the tape and use that. I just used a 4.5" cutting wheel and went around it and it turned out pretty good.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #8 of 23 Old 10-01-2010, 08:52 PM
DDove
Chop saw help
This may sound strange, but I really don't know about this. If I have a compound mitre saw can I put a chop saw blade in it? It is a 10 inch blade. As always thanks!
DDove is offline
post #9 of 23 Old 10-01-2010, 08:56 PM
DDove
Sorry about that, I did not mean to post this question here and hijack your thread
DDove is offline
post #10 of 23 Old 10-02-2010, 05:03 PM
johnny9
some people are totally against it but you can also use a torch,set it properly and cut it smooth and fast and the metal wont have a lot of time to get to hot,then grind it to the finish fit.kinda a pita but ive done it when ive had to more than once.not the best method but no one would no it after it was welded.
build-
johnny9 is offline
post #11 of 23 Old 10-02-2010, 05:05 PM
g4x4xgeoff
I either cut with an angle grinder, or with a torch. Not a big deal with to do it with a torch.
I've found if you heat the surrounding area slightly before cutting, it yields a cleaner cut, which results in less grinding afterwards.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #12 of 23 Old 10-02-2010, 05:19 PM
johnny9
yeah when you get good with a torch anythings possible..i remember 30 yrs ago learning why "not" to cut stuff out on concrete also..snap crackle pop
build-
johnny9 is offline
post #13 of 23 Old 10-02-2010, 05:28 PM
g4x4xgeoff
cutting on concrete is....fun....
post #14 of 23 Old 10-02-2010, 06:05 PM Thread Starter
slafferty
By the way i also have a plasma cutter... and i know all about using it on concrete. Really the main problem i have is marking the pipe evenly, it i had some templates with different anlges i could trace it and cut it with the plasma just fine..
MY BUILD THREAD
post #15 of 23 Old 10-02-2010, 08:07 PM
Ironworker709
You can also pick up some pipe wrap,looks and feels like gasket material...Pipefitters use it regularly....wrap a section of it around the size tube you want to cut and tape it so you can slide it off the tube and hold it's size.
Then use it to experiment with the angles and maybe notches if needed and use it for a test fitting...once you're satisfied with that fit,you can slide it right back onto the tube and mark it with that,plus you can keep that peice for when needing that same angle for a pattern over and over
Never forget 9/11
Pipe vs. tube.... lets discuss BamaJeeper Fabrication Shop 58 10-10-2011 05:45 PM
Tube/Pipe bender quality, price and purpose Godchsr Fabrication Shop 4 02-27-2009 07:40 AM
Where can I get pipe/tube bent? Deadhorse Fabrication Shop 4 02-10-2009 08:20 AM
online tube cutting template maker rudyyj Fabrication Shop 3 02-05-2009 01:38 PM
Cutting Tube TMXONR Fabrication Shop 10 05-18-2008 07:15 PM
