Cutting aluminum diamond plate? - Page 2 - JeepForum.com
post #16 of 28 Old 02-21-2011, 07:22 AM
dodger889
Putting a blade in backward still cuts but does not bind up. I used a plywood blade smaller teeth.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #17 of 28 Old 02-21-2011, 07:56 AM
fatbob60
Out of curiousity, why does flipping the blade backwards work?
I cut aluminum channel with my chopsaw all the time, but obviously this is not that same.[/QUOTE]
A standard woodcutting blade has too much rake on the teeth, making for a dangerous and aggressive cut. Having the blade backwards, prevents that, keeping kick-back to a minimum.
A non-ferrous metal cutting blade has very little rake on the carbide teeth, which also reduces that DANGEROUS kick-back.
fatbob60 is offline
post #18 of 28 Old 02-22-2011, 06:10 AM
paintballtruck
1979 J-Series Truck
by running it backwards it doesnt plug up and it doesnt kick back as much i have used one at work a lot of times replacing floors in refrigerated semi trailers very loud but works just fine
paintballtruck is offline
post #19 of 28 Old 02-22-2011, 09:20 AM
VIJeeper
At the sheet metal shop I worked in we used a hand held jigsaw. I use the jigsaw at home on aluminum and it works great. Leave a regular "wood" blade in and have at it.
My Jeep: 2007 Wrangler Unlimited X. Rescue Green, 6 speed.
VIJeeper is offline
post #20 of 28 Old 02-22-2011, 10:22 AM Thread Starter
JFD140
2011 JK Wrangler
Cut the 3 main pieces of the plate this morning. Came out dead straight. Used a circular saw with a wood framing blade 24 tooth, no problems. I did not turn it backwards or anything i just set the depth of the blade to 1/4" so there was nothing to even allow binding.
Jigsaw is up next... Cringing about messing up this part. As long as i get the main center piece perfect, im on track.
JFD140 is offline
post #21 of 28 Old 02-22-2011, 11:57 AM
speedbucket
perfect depends on how far away you are when you look at it
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #22 of 28 Old 02-22-2011, 04:06 PM
4.7stroker
Believe it or not laying down tape over the line you are going to cut makes the cut cleaner, I don't know why but it does. I just lay down tape re-draw my cut line and have at it. I prefer to use a table saw with the blade in the correct way.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #23 of 28 Old 02-22-2011, 05:56 PM Thread Starter
JFD140
2011 JK Wrangler
Well here is what i got done today.
Very happy with my progress and how great it came out as far as the cuts. I was really worried i would screw up the big mid section and be out $100.
Cutting curves that dramatic with a jigsaw - PITA. Really likes to bind up but i got through it. Also... dangerous edges had to file those down as soon as i got home to a file.
I am currently trying to figure out how to, or find a place to put a bend in the front and back of the midsection piece for both strength and to tie into the tailgate door. One place wanted $75... for 5 minutes of their time...
JFD140 is offline
post #24 of 28 Old 02-25-2011, 11:56 PM
DeViOuS_CJ5
1980 CJ5
nice work man
DeViOuS_CJ5 is offline
post #25 of 28 Old 02-26-2011, 11:39 AM
fitbmxseries1
1987 YJ Wrangler
finish it off with some of this stuff, they have it in chrome or black
http://www.autozone.com/autozone/acc...questid=396793
2005 Jeep grand Cherokee WK 2" rough country lift 1.25 wheel spacers 255/75/17
Blue WK club #5
1987 Jeep Wrangler YJ, random leafspring budget lift ith 33s on 16s and V8 swap.
1999 Jeep Cherokee XJ --SOLD.
fitbmxseries1 is offline
post #26 of 28 Old 02-26-2011, 04:08 PM
VmanR32
Nice work. Makes me appreciate my plasma cutter that much more, that and the fact we have a water jet cutter at work.
VmanR32 is offline
post #27 of 28 Old 02-27-2011, 01:56 AM
dodger889
You would like the wider black rubber edging better to control noise.
post #28 of 28 Old 02-27-2011, 03:48 PM
fitbmxseries1
1987 YJ Wrangler
i couldt find the bigger stuff on their site, but i found a bunch on ebay.
Blue WK club #5
where to get diamond plate? JFD140 Fabrication Shop 3 02-10-2011 09:00 PM
painting aluminum diamond plate walkingcrow Cheap Tricks & Fixes 11 05-26-2010 05:50 AM
Aluminum Diamond Tead Question zeke6785 Fabrication Shop 6 03-27-2009 05:33 AM
Bending Aluminum Diamond PLate Scrambler82 Fabrication Shop 8 09-07-2007 07:01 AM
diamond plate Super Jeep General Jeep & Off-Road Equipment 2 01-22-2006 09:24 PM
