Cutting aluminum diamond plate? - JeepForum.com
post #1 of 28 Old 02-20-2011, 04:08 PM Thread Starter
JFD140
2011 JK Wrangler
What is the best way to cut this stuff...
I am building a lid for the trunk of my JK when the top is off.
Obviously i am using a jigsaw with a 36 tooth blade for the curved cuts but the straight lines...
Should i just use a circular saw with a new blade? How many teeth? I only have a pretty new 24 tooth framing blade at the moment, they had a 40 tooth for $10.00 at hope demot...
JFD140 is offline
post #2 of 28 Old 02-20-2011, 04:16 PM
Unlimitedlou
I often use a 4 1/2 grinder with a cutting wheel. The other option would be to find a shop with a metal brake.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #3 of 28 Old 02-20-2011, 04:25 PM Thread Starter
JFD140
2011 JK Wrangler
that wont make a dead straight cut... (the grinder)
A circular saw should cut through it no problem if i move slowly... i just don't know how many toothed blade i need... i assume more is better.
I mean i also have a grinder cutting blade for the circular saw... but i dont think it will make that nice of a cut...
JFD140 is offline
post #4 of 28 Old 02-20-2011, 04:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've never cut aluminum with a circular saw before.. but it sounds like fun.
If I were going to try it, I'd probably use a pretty fine carbide tooth blade (to avoid tearing the edge) and run the blade shallow.. only coming thru as far as needed to severe the sheet. I'd clamp the plate to a solid work bench to keep both hands on the saw in case of kickback. I'd probably also clamp a 2x4 in place as a straightedge to run the saw against for a nice straight cut.
Should be able to clean the edge up with a flap disk after cutting..
BESRK is offline
post #5 of 28 Old 02-20-2011, 04:38 PM
speedbucket
get a couple of 7 1/2" carbon blades and use on a circular saw, blades are cheap, you will have an extremely sharp edge! hit it with a grinder
speedbucket is offline
post #6 of 28 Old 02-20-2011, 04:38 PM Thread Starter
JFD140
2011 JK Wrangler
exactly what i was gonna do... but maybe i would be better off with the abrasive blade than a carbide... il try cutting a scrap first i guess.
JFD140 is offline
post #7 of 28 Old 02-20-2011, 04:39 PM
speedbucket
and tools always make straight cuts! people dont!
post #8 of 28 Old 02-20-2011, 07:08 PM
jason m
Nothing but the facts
jason m's Avatar
Install the skill saw blade backwards. Ive done this alot and it works great. Not sure the tooth count but its the one I used on wood and it got dull for that.
Went threw 1/4" ALU like butter.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #9 of 28 Old 02-20-2011, 07:12 PM
Kenbo-Slice
Flip the sheet face-down so you're working with a flat surface. Clamp a straightedge and use it as a guide with a jigsaw. DO NOT use an abrasive blade, it will clog and be an annoyance.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #10 of 28 Old 02-20-2011, 07:59 PM
fatbob60
Jason.
x2 onthe backwards blade.
Aluminum cutting blades are available, mostly at specialized shops, special order at lowes, home depot...
fatbob60 is offline
post #11 of 28 Old 02-20-2011, 08:42 PM
Ironworker709
Ironworker709's Avatar
You can buy Alumimun cutting Carbide tipped blades for a circular saw at most home stores now..i have a gotten a few from my local Lowes in Statesboro,Ga...maybe they don't all carry it in stock?..dunno
Jason is right..just turn a regular carbide tipped circular saw blade backwards and it cuts it no problem,but make sure you'r wearing a face gaurd and safety glasses and long sleeves..the aluminum chips fly everywhere.
Regular carbon abrasive blades in a chop saw will last maybe a few seconds before it clogs and won't cut worth a darn at all....grinder wheel/cutting blades are the same way.
Oh yea..one more thing..EARPLUGS..you are about to make more noise than a 747 flying through the shop..lol
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #12 of 28 Old 02-20-2011, 09:54 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
If you use a circular saw and a fence you will go off course if you go too fast. The blade will ever so slightly go off course and eventually you'll be off your line. Trust me on this one - go slow and pay attention!
Personally I would use a 4.5" angle grinder. I can cut a much straighter line with this than I can with a circular saw.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #13 of 28 Old 02-20-2011, 10:47 PM Thread Starter
JFD140
2011 JK Wrangler
dont have one... not really looking to buy new tools to use them once
Out of curiousity, why does flipping the blade backwards work?
I cut aluminum channel with my chopsaw all the time, but obviously this is not that same.
JFD140 is offline
post #14 of 28 Old 02-21-2011, 05:51 AM
DeViOuS_CJ5
1980 CJ5
i cut this stuff everyday almost...best thing is find a shop to shear it cause whenever you cut this stuff it likes to melt kinda and you'll end up with knarl marks verywhere when your trying to clean up the edges...jmo
DeViOuS_CJ5 is offline
post #15 of 28 Old 02-21-2011, 06:44 AM
Jim1611
Jim1611's Avatar
Ever tried one of these? I bought one, cost $35.00, and it really works great.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
where to get diamond plate? JFD140 Fabrication Shop 3 02-10-2011 09:00 PM
painting aluminum diamond plate walkingcrow Cheap Tricks & Fixes 11 05-26-2010 05:50 AM
Aluminum Diamond Tead Question zeke6785 Fabrication Shop 6 03-27-2009 05:33 AM
Bending Aluminum Diamond PLate Scrambler82 Fabrication Shop 8 09-07-2007 07:01 AM
diamond plate Super Jeep General Jeep & Off-Road Equipment 2 01-22-2006 09:24 PM
