-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Custom UHMV skid plate (http://www.jeepforum.com/forum/f37/custom-uhmv-skid-plate-1526038/)
SFRautomotive 05-20-2013 06:34 PM
figured some of you may be interested in this, i wish i would have taken more pictures during the framing part of the build but i was trying to move through it at a nice pace.
anyways, i needed to build a skid/trans mount for a customers CJ8 build. needed to be reasonably low profile and still protect the dana300 and TH400, along with containing a mounting point for the trans mount and the stub half of the 2 piece driveshaft setup.
i first drilled out some holes and welded in some 1/2 ID bosses
http://i1093.photobucket.com/albums/...327_141122.jpg
then took some 2x2x.25 angle and conformed it to the shape of the frame and framed it up with some 1x1x.120 box tube and some 1x2x3/16 tube, then welded some angle up for the driveshaft and trans mounts
painted it up
http://i1093.photobucket.com/albums/...psdd456c74.jpg
http://i1093.photobucket.com/albums/...psfb9bae4b.jpg
took some 1/8 plate steel and cut out the 3 panels i would need to cover the skid.
http://i1093.photobucket.com/albums/...ps2d7485d9.jpg
http://i1093.photobucket.com/albums/...psb6a8b756.jpg
then began the process of drilling out all the plates and drilling and tapping the framework
http://i1093.photobucket.com/albums/...ps743ca8a9.jpg
http://i1093.photobucket.com/albums/...psac271bef.jpg
painted the steel up
http://i1093.photobucket.com/albums/...ps6e92eafc.jpg
and the impact resistant 1/2" UHMV showed up
http://i1093.photobucket.com/albums/...ps21caa238.jpg
set the plates up and outlined the cuts i needed to make
http://i1093.photobucket.com/albums/...psd90a295f.jpg
bolted the plates to the framework and put a few welds on it to help it keep its shape
http://i1093.photobucket.com/albums/...ps78b358d7.jpg
cut out the UHMV and put a shallow groove to help with the bending. and marked all the holes for drilling and countersinking
http://i1093.photobucket.com/albums/...ps6a2e16d5.jpg
the UHMV was drilled and all the edges were angled
and bolted it all down and used a heat gun to help make the bends in the UHMV more permanent
and also added 6 seperate bolts that are only there to hold the UHMV to the steel plate so that when the skid is removed the plate stays attatched the UHMV. the bolts are painted white to keep from confusing them with the other bolts
http://i1093.photobucket.com/albums/...ps6301115f.jpg
http://i1093.photobucket.com/albums/...psccd4180d.jpg
http://i1093.photobucket.com/albums/...ps2a271a6a.jpg
http://i1093.photobucket.com/albums/...psdfc12671.jpg
http://i1093.photobucket.com/albums/...ps77d7b744.jpg
http://i1093.photobucket.com/albums/...ps5e602da1.jpg
http://i1093.photobucket.com/albums/...ps75641b92.jpg
http://i1093.photobucket.com/albums/...ps80ca028e.jpg
http://i1093.photobucket.com/albums/...ps1d8f339e.jpg
annnnnd, thats it:wave:
wushaw 05-20-2013 06:59 PM
Nice!
lar308 05-21-2013 05:31 PM
Very nice, I'll be using some of you ideas, if you don't mind. Ron
SFRautomotive 05-22-2013 09:03 AM
Thanks.
Go ahead, use what you want
Copperhead89 05-22-2013 07:37 PM
Nice job! BTW, the abbreviation for that type of plastic is UHMW. It stands for Ultra High Molecular Weight. I used to design parts made of that material for the food processing industry.
The time now is 05:05 PM.
