Custom off road trailer - JeepForum.com
post #1 of 24 Old 03-02-2011, 11:22 AM Thread Starter
trailrated1989
Ok I am going to start out by saying, this project will be around a year out. But I am trying to get everything I want down on paper now. So what do you guys think about using a Jeep tub? I know it has been done before. But the reason I want to use one, is so when I am on the trail, I can take my doors off and put them on the trailer. I would be doing alot of sheet metal work in side and out for this project. But I think it would be pretty cool. I also would be building my own frame. Also another question is, does anyone know the ruff guess of a tubs weight? Because if it is way to much then I will just scrape the idea. Thanks in advance for any comments or direction pointing. Also the picture is not my tub. Its just one off of google for reference.
trailrated1989 is offline
post #2 of 24 Old 03-02-2011, 11:29 AM
goolsbayjeep
why don't you just remove the back seat and store the door behind you?
goolsbayjeep is offline
post #3 of 24 Old 03-02-2011, 11:45 AM
00JGC00
I don't think it's a bad idea. It can't way that much more than a truck bed trailer. I really don't think it's a bad platform to start with as long as you're okay with it being a very long and committed project. I say go for it.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #4 of 24 Old 03-02-2011, 12:07 PM Thread Starter
trailrated1989
I have full steel doors. And I have two kids that like riding in my Jeep more than I do. Also I have been wanting a trailer for camping reason. I started thinking about this last night. So I thought I would throw this out there to get feed back.
post #5 of 24 Old 03-02-2011, 12:09 PM Thread Starter
trailrated1989
I like projects. This will be my biggest one that I will have done. But I think once I get started I will finish it. Because the way I am, if I have to spend money on something. I am going to finish it or else I wasted money.
post #6 of 24 Old 03-02-2011, 12:13 PM Thread Starter
trailrated1989
Another though, for towing reason. Would the axle/tires be to far back? Because I know most of the time trailers try to have centered axles.
post #7 of 24 Old 03-02-2011, 12:23 PM
00JGC00
Well the further back your axle is, the more weight you potentially put on the tongue. What is the max tongue weight on a TJ?
00JGC00 is offline
post #8 of 24 Old 03-02-2011, 12:33 PM
firefighter315
IIRC, the tub weight minus roll bars is in the neighborhood of 300 lb.
My YJ Build Thread
firefighter315 is offline
post #9 of 24 Old 03-03-2011, 06:19 AM
BSInc
that weight sounds about right. 2 guy really groaning to move mine around completely stripped.
As for axle location, I closed my tub out just ahead of the back door brace (trailer is 5') and I'm glad I left the axle in the stock location. I wheel with my family too and it's nice to be able to sit on the tailgate without lifting the tongue in the air when it's unhooked. I used a cj tailgate.
BSInc is offline
post #10 of 24 Old 03-03-2011, 06:25 AM Thread Starter
trailrated1989
Could youngest some pics of your trailer?
post #11 of 24 Old 03-03-2011, 09:36 AM
timatoe
timatoe's Avatar
The part about putting the doors "on" the trailer has me a bit confused, are you going to be using from the firewall back to just past the door opening and then moving the tailgate area up to that point?? If so you're looking at basically a flat bottom trailer and you can position the axle wherever you need to. My concern would be where the tires will sit if that's the case, because if they're under the tub it will sit very high and if they're outside of the tub they will likely interfere with the door area.
If you're going to be using the rear portion of the tub, the "bed" if you will, then I'd just use the frame that's there and use a standard trailer axle with leaves at the right width and weld the hangers to the stock frame basically centering the wheels in the stock opening.
BTW, when I re-did my little trailer I found ABC Trailer Parts to have the best prices, and very good customer service.
timatoe is offline
post #12 of 24 Old 03-03-2011, 10:12 AM
rdsk8ter
1982 CJ7
heres my thread on mine
http://www.jeepforum.com/forum/f104/...ailer-1164102/
Check out the hitch its kinda the pride of the build. Heed my warning these are addictive
rdsk8ter is offline
post #13 of 24 Old 03-03-2011, 11:23 AM
kcaverly
I think it's a great idea. I'm planning a similar build myself this spring. Your lines do have me a bit confused though too. Can you clarify which bits your cutting and moving where?
General rule for axle location is the weight distribution should be ~60/40 in front of/behind the axle. That gives you roughly the right amount of tongue weight, as well as a fairly stable trailer for towing confidence. It also makes it easy to maneuver and back up.
Kevin
1993 Jeep YJ - 350 Chevy TBI, SM465, NP241, 14B SF LSD, 10B
kcaverly is offline
post #14 of 24 Old 03-03-2011, 11:29 AM Thread Starter
trailrated1989
Kevin
Sorry for the confusion. I will be taking out the area behind the fender well and sliding the tailgate up some. And taking the area between the fender well and the door out. And cutting out most of the firewall. Just so shorten it up a bit. Right now I am just trying to get ideas.
post #15 of 24 Old 03-03-2011, 11:30 AM Thread Starter
trailrated1989
The axle would be in the fender well. Also I would want to do my own frame, so that way I can try to shave a little weight out of it. Also thanks for the link.
Designing custom trailer and 3 axis hitch Zybeon Fabrication Shop 17 11-21-2016 06:52 AM
off road expo trailer flopp00 Fabrication Shop 2 08-27-2010 01:36 PM
off-road trailer to tow behind my ZJ 5.9 ANDY General Jeep & Off-Road Equipment 58 02-06-2008 01:04 PM
trailer for off road Airborne Lee General Jeep & Off-Road Equipment 16 01-16-2007 11:08 PM
off road trailer projects 98JPTJ General Jeep & Off-Road Equipment 3 03-19-2006 11:08 PM
