Custom Hi-steer Dana 44 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Custom Hi-steer Dana 44
NOTCH CUSTOMS - Max Clearance Fender FlaresZone Offroad Suspensions Now At FUELED 4WD!New Products From Factor 55 Now Shipping At FUELED 4WD!
Unread 10-17-2007, 08:45 PM   #1
Slc
Heres an upgrade I started yesterday. Beefing up the crappy steering to 1.5" tubing.
Slc is offline   Reply With Quote
Unread 10-18-2007, 12:31 PM   #2
tweba99
How is that Hi-steer and how is that any better than just going over the knuckle with the same steering setup?
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote
Unread 10-18-2007, 12:47 PM   #3
skullver
Tarpitz
1991 XJ Cherokee
looks like d30 outers to me, is that a rubi 44 or am I missing something? Fab work looks nice even though I don't quite understand what you are shooting for.
Chris
Blah blah blah blah.
my Jeepspeed build thread:
http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/
skullver is offline   Reply With Quote
Unread 10-18-2007, 02:22 PM   #4
j0nesy
yeah ... looks like a rudi '44' ... nice work ...
j0nesy is offline   Reply With Quote
Unread 10-18-2007, 09:31 PM   #5
Slc
Its a Rubi Dana 44, maybe I should of labeled the post "steering upgrade". I replaced everything with 1.5" dom tubing, 1/4" wall, due to the 37" tires and the crappy bent up stock tie rod.
Unread 10-18-2007, 09:49 PM   #6
wil badger
and to help you clarify why you made the plated to move the loacation outward.when swapping to a cross over steering of this type the tierod bar will come in contact with the diff cover when at full lock.by making the plates and moving the tie rod outward it moves it away from the diff cover allowing full steering again.
One Built XJ
wil badger is offline   Reply With Quote
Unread 10-18-2007, 10:07 PM   #7
Slc
Yes it moves it out to clear the diff cover, espaically a Super Lift cover.
Unread 10-18-2007, 10:59 PM   #8
jason m
looks good, i did the same to my 60 arms http://www.jeepforum.com/forum/f27/dana-60-high-steer-arms-renforcement-468940/, jason.
jason m is offline   Reply With Quote
