Custom BL - JeepForum.com
post #1 of 5 Old 04-08-2007, 11:42 PM Thread Starter
Cineris1104
Custom BL
Ok, I realize that this isn't really considered "fabbing," but I was wondering if anyone here has made a body lift themself? My dad works at a machine shop and has access to aluminum, steel, titanium, magnesium, etc. stock and was thinking about making a body lift for me, but doesnt know the right diameter for the spacers, or inside hole, nor how to bevel it. Anyone done this before?
Cineris1104 is offline
post #2 of 5 Old 04-09-2007, 05:07 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Best bet would probably be to take a look at an aftermarket body lift puck and copy the dimensions. Barring that, I'd go the same diameter as a typical stock body puck and make the inside dimension a slip fit for the body bolt.. should be pretty easy.
BESRK is offline
post #3 of 5 Old 04-11-2007, 01:10 PM
mawardjr
A buddy of mine used hockey pucks for his 1" body lift.
They also make nice bumpstop extensions.
99 cents a piece at our local Play It Again Sports outlet.
'98 ZJ - "Luxo": Drive train: 4.0L, 42RE, 242, HP30 (Lockright)/8.8 (Detroit) Protection: Skids (Engine, Oil, T-Case, Gas, FLCA,Diff), LP-1 sliders Recovery: Rusty's hooks, Class III Hitch Suspension: RE 4.5" SuperFlex, JKS disco's, RE Monotube, Adj Trackbars Wheel/Tire: TrXus 33x12.5-15, RC's 15X8 3.75"BS Misc: CB, Hi-Lift, Tube Doors
mawardjr is offline
post #4 of 5 Old 04-11-2007, 04:12 PM
Heepajeep
you could always order a body lift kit, copy all the pieces then return the kit.
Heepajeep is offline
post #5 of 5 Old 04-11-2007, 07:39 PM
360wrangler
i used
i used 1/2 hole and 1 1/2 round alum. stock
"build it to break it, if it breaks it wasn't built well enuf"
360wrangler is offline
Custom stencils for a custom dash. Badkarma1354 General Jeep & Off-Road Equipment 2 04-14-2009 01:52 PM
custom sub box airframer Fabrication Shop 2 04-11-2008 10:10 AM
Custom XJ Box MSHarnett Audio, CB & Ham Radios, GPS, & Electrical 4 03-25-2003 02:20 PM
custom sub box ldogg Audio, CB & Ham Radios, GPS, & Electrical 45 03-11-2003 02:01 PM
custom tie rod rustyCJ Tires & Wheels 6 01-29-2003 12:38 AM
